What cam for Explorer Topend?
  • Thread starter Thread starter Blown95Cobra
  • Start date Start date Jan 5, 2007
Blown95Cobra
58
Spring Hill, FL
Jan 5, 2007
  • Jan 5, 2007
I'm going to get a set of GT40 heads and an Explorer intake manifold with TB. What cam should I run? I'm thinking about using a TFS Stg 1. The car is pretty stock, 4.10's, 5spd, longtubes, and 2.5" catless exhaust. I also have a set of 24# injectors with a 76mm C&L MAF that will go on with the H/C/I.
Thanks,
Frankie
RYC CUKR
1,437
Orlando
Jan 5, 2007
  • Jan 5, 2007
The stage 1 is a good of the shelf cam. I run one in my 93. Originally it had a GT40 intake and P heads. Swapped the intake for a TFS track heat. Was pretty happy with both combos with the stage 1 cam.
89streetbeast
365
horton,ks
Jan 5, 2007
  • Jan 5, 2007
crane 2031 has some pretty good midrange and topend power but no lopey idle. since you got 4.10's id look at something in the mid range since you got the sotp torque with the gears. just my 2 cents
V
v8only
2,378
22
49
Jan 5, 2007
  • Jan 5, 2007
my bro went with the tf1 one cam, I went with the HO cam. Really the HO cam isn't bad at all even with gt40/p heads and intake.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jan 6, 2007
  • Jan 6, 2007
Adjustable timing gear and a stock cam degreed... Our GT40P combo runs very well with this set up!
Blown95Cobra
58
Spring Hill, FL
Jan 6, 2007
  • Jan 6, 2007
Are you talking about the stock 87-93 cam?
I'm doing all of the work myself and I dont know how to degree a cam. I'm not even sure what degreeing means lol. Is adjusting the cam timing to work where I want it to degreeing? If so, how do you figure out how far to move it?
SPEEDYLIFSAVR
666
FL,89 LX 5.0
Jan 6, 2007
  • Jan 6, 2007
I'm doing my H/C/I right now , using pretty much an explorer set up . Ported gt-40p's with Cobra intake . I installed an E-cam because I wanted to stay brand specific on all my parts . I'll let ya know how she runs very soon!
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jan 6, 2007
  • Jan 6, 2007
You get the adjustable timing gear and it allows you to retard or advance the cam. Ours is retarded 4 degrees, and moved the powerband up!
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Jan 7, 2007
  • Jan 7, 2007
The E-cam with the explorer set is a decent runnign set-up. Put one in a an Explorer motor I did for a guys 90GT. The e-cam should of been the stock cam for the 93 Cobra's IMO. Works well with with the GT-40 heads and Cobra/Explorer intake.
But I would run the TFS stage 1 personally. That is a really nice OFS cam. Sounds killer and performs real good. This cam is liek the old Lunati 51014 & Wolverine 1087 of the day..
legalize420
1,541
South Florida
Jan 7, 2007
#10
  • Jan 7, 2007
  • #10
+1 for the e-cam. i ran on the bottle for the first time the other night. im sure i could knock a few more tenths off that 12.7
86nu
94
Birmingham, Al
Jan 7, 2007
#11
  • Jan 7, 2007
  • #11
id pick something else other than an e cam, they were good, but cam tech has come such a long way.
cammotion.com 130 bucks or so for a fully custom cam to your specs, needs etc etc cant go wrong that way
F
FiveOoutlaw
34
#12
  • Jan 7, 2007
  • #12
My setup is a set of worked 93 cobra heads, explorer manifold, and the tfs 1 cam. I love it, it still has good power down low but just pulls harder and harder up top. very streetable with a great lope to it. I havent had it dynoed yet but I ran dead even with a coupe that put down 287 to the wheels, and my car is a decent bit heavier.
Blown95Cobra
58
Spring Hill, FL
Jan 12, 2007
#13
  • Jan 12, 2007
  • #13
Thanks for the help guys. I think I'll go with the TFS1 just because a lil more lift never hurt anyone
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
