First you need to decide the heads you are going to run. You then need to figure out flow specs on that head. If you can't find them, PM me and I'll you what the heads flow. The heads, based mostly on the flow numbers, should determine which intake you choose to accompany them. Then, and only then, should you pick your cam. If I were you, I'd go custom, but most people for some reason don't like the thought of doing this although it'll only run you about $100 more than an off-the-shelf cam, and if even 5hp is gained, which is very conservitave, it's still worth the money in the hp-per-dollar ratio. If you don't want to go custom, then I'd email Comp Cams or Anderson Ford Motorsport to see what they reccomend for your car. You could do others such as Crane or Lunati, also.
