What Drivetrain Should I Get?
Hey all!
I'm getting a progressively worse vibration coupled with a bit of morning sickness on my '67 vert. It currently has a C-4 trans.
Now that I have to fix all this, I've decided I want to upgrade the entire drivetrain, beginning with an AOD trans, new drive shaft, and LSD. I may or may not need to replace my rear end. It's an 8" currently. Should I go 9"? If heard that is a good idea.
It is a daily driver, so I need the low RPMs at high speeds on the freeways, but I'd also like respectable off-the-start power, even though I'll never race it.
So here's the question: Beginning with a TCI AOD transmission, what else do you all recommend I get to complete the project? (brands, sizes, ratios, etc.)
I've seen a couple articles from Mustang Monthly and Mustang 360, but I wanted to get your input if possible.
Thanks in advance!
A tip on the AOD output shaft: Make sure you get a 7 tooth output shaft vice the 8 tooth. It will make speedometer calibration that much easier!
Also; back when the 5.0 Mustangs were so popular, most of the guys with the AOD transmissions were running 3.73 or 4.10 rear gears on the street.
Reactions: Nathaniel Donnelly
Thanks again guys.
I called around, and it looks like the Mustang Shoppe here in SD has the best deal to make the conversion: $4500 out the door not including the rear end. Best price I saw by about $1000, and they specialize in Mustangs, so I know they'll do it right.
Turns out my progressively worse vibration was a slowly-deflating tire (sidewall tread hitting the pavement when I went over bumps and dips). Hardly registered any PSI! (below 20) So the rest of the driveline may be fine.
Any additional thoughts?
