What is the proper way to set timing on a 90 lx.5.0
90lxboost'n
55
Ohio
I have a 90 lx 5.0 with an explorer u/l intake an E cam c&l 76mm mas 24lb injectors cold air intake 3.73's I set the timing on what was showing to be 12 degrees on the light, and the car just does not pull like I think it should also no knock at all. I set the timing this way, I pull out the plug start the car set timing shut car off and reinstall the plug(small chip near dist.). I have a 99 grand prix gtp that I feel will kill the mustang and it is a 4 door grocery getter. Any suggestions on what I should do would be appreciated. Thank you...
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
