  • SN95 4.6L Mustang Tech
What programmable tuner is BEST?
  • Thread starter Thread starter mdvaldosta
  • Start date Start date Jun 12, 2004
mdvaldosta
72
  • Jun 12, 2004
Just looking for opinions on a tuner that is simple to use and has alot of tunability. Anticipating a cam change and I was gonna drive to T&J for a tune, but thats a LONG way to drive. So, for under $500.00, anyone recommend a tuner that can adjust a/f ratio and timing across the board, and of course do the other expectable things as well. Didn't Bill Putnam use a programmable tuner when he did a cam swap?
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Jun 12, 2004
  • Jun 12, 2004
They're pretty close but the SuperChips Tuner and the Diablo Predator Tuner both have their pros and cons.
If $500 is your budget, the Diablo will do you fine. If you're willing to spend a little more ($750-800) you can get the SuperChips Tuner which apparently has more options.
I think Stangnet is split 50 / 50 and honestly I'm not sure which one is best for me either.
jstreet0204
939
Winston Salem, NC
Jun 12, 2004
  • Jun 12, 2004
for around $500 you can get the TwEECer RT with datalogging. There is a goog bit to learn but there are support forums and I have found them very helpful.
03gtmustang
923
Northern Va
Jun 12, 2004
  • Jun 12, 2004
I have the superchips microprogrammer right now (not the SCT), I think Im going to sell it and buy the diablo programmer.
mdvaldosta
72
  • Jun 12, 2004
why
Go HoTO!
602
Mountaintop, PA
Jun 12, 2004
  • Jun 12, 2004
The SCT sells for about $400 as does the Diablo. The SCT Racers package give you total control of the tune and is I think about another $400 or so.
mdvaldosta
72
  • Jun 13, 2004
Does the Diablo give you full control of the A/F ratio - or just modifying the whole band a certain %?
M
moreause
74
  • Jun 13, 2004
it give you 2 stage 2000-4000 and 4000 to 7000 rpm when you want to*change a/f
W
WOT
2,817
Regina, Canada
Jun 13, 2004
  • Jun 13, 2004
I say get a EFI Solutions set up. Give T&J a call.
It allows adjusting of a lot more then just A/F.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Jun 14, 2004
#10
  • Jun 14, 2004
  • #10
I went with the SCT Pro Drag Racer package (chip version) just before the cams so I could work through any idle issues that are related to the cams. I could have gotten the cheaper package but I wanted full control over everything in the PCM for my future upgrades.
Bill
mdvaldosta
72
#11
  • Jun 14, 2004
  • #11
Is the software easy to use? If Im correct, Bill, you had a dynotune done after your cam install. Was they dyno time just to see the results of the cam change hp increase, or was it for further tuning?
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
5K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
Progress Thread finishing touches on my stroker build
  • doobismaximus
  • Jul 2, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2021
nickyb
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
72K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
E
Guys, I Need Some Opinions On A Build.
  • E36
  • Dec 24, 2016
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 13, 2017
E36
E
