Where to get a good shortblock?
  • Thread starter Thread starter ras50gt
  • Start date Start date May 10, 2020
First Prev 2 of 2
96pushrod
I think they're a little easier to get off
5 Year Member
May 15, 2018
1,530
871
133
Savannah
May 31, 2020
#21
  • May 31, 2020
  • #21
I do believe if you supply a block without cracks Woody will work out a way to do a stock block for you. By the time it’s all machined and ready for assembly though you’re only saving in the $1000-$1200 neighborhood over going with a dart block. It’s not exactly chump change, but kind of something to think about. A dart block will more than likely be the last block you’ll buy, save unless something catastrophic happens. Even if you choose to go 4.125 bore there is still several rebuilds to go before thinking about cylinder wall thickness.
If going stock block I’d just get one out of a junkyard and put a set of pistons in it (for some compression). Probably will have to get the rotating assembly balanced, unless the weight is spot on to the stock ones, but it’ll be your cheapest route. Usually the fuel injected 5.0 long blocks are pretty cherry when you crack them open.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,131
2,758
224
Vass, NC
Jun 6, 2020
#22
  • Jun 6, 2020
  • #22
CarMichael Angelo said:
That was him. The good Captain @FastDriver can speak to that. He was one of the customers that had to bail on the guy when he couldn’t fulfill the order.
Sorry guys. I check back in when I can, but I've been way more busy with work, now that I'm no longer a student in grad school, this year.
I don't know what happened to Rick. He just completely dropped off of the net. I'd asked him to do quite a few things on my black car. I even sent a pristine black dash that cost a couple hundred bucks out to him. After he dropped off, I never heard from him again. Never got a refund or anything for the dash. Was too busy to bother with it, and never sought him out for the dash/cash/legal remedy. He did good work on Joe's car, which I now own. I hope he's doin' alright out there.
Reactions: revhead347 and General karthief
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 6, 2020
#23
  • Jun 6, 2020
  • #23
The stupidest thing I ever did was go with a stock block on my second stroker engine. Budget was real tight back then. Just get the stinking Dart block.
Kurt
silverlx50
168
62
38
Jun 6, 2020
#24
  • Jun 6, 2020
  • #24
Save and go with the Dart at Fordstrokers. Woody will build a hell of a motor. I bounced back and forth between a Dart long block from Woody and a Coyote swap. I went with a 347 Dart from Woody and I am beyond happy.
First Prev 2 of 2
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
