Progress Thread Wrong motor angle
  • Thread starter Thread starter RileyDymond
  • Start date Start date Yesterday at 8:32 PM
  • Tags Tags
    302 5.0 tubular k member
RileyDymond
18
Ny
  • Yesterday at 8:32 PM
So I have an issue where my motor and transmission are definitely sitting at the wrong angle I’m running a tubular k member with stock style motor mounts everything is sitting loose and bottomed out I’ve put an extra spacer (than it calls for) underneath my tranny mount to try and even it out. 5° seems to be awfully steep. Any advice on what to check for. TIA!
KRUISR
1,897
1,034
143
Yesterday at 8:39 PM
  • Yesterday at 8:39 PM
Is the rest of the car level? Measure the vertical face of the output shaft/driveshaft yoke. Measure across the balancer/crank pulley. I am not sure if the top of the intake is parallel to the crank centerline, same for bottom of case on trans.
Are those measurements the degrees of the engine up or down from level? How level is the bottom of the pinch welds on the rockers (both sides)? This will give a frame of reference for other measurements - then we can make suggestions.
Reactions: Blackhawkxx
RileyDymond
18
Ny
Yesterday at 8:47 PM
  • Yesterday at 8:47 PM
I set my angle finder on 0° off the pinch weld and my tail shaft just measured at 4.2° and balancer was at 5° and the pinch welds are level side to side going up at the same angle
KRUISR
1,897
1,034
143
Yesterday at 8:58 PM
  • Yesterday at 8:58 PM
Incline going up from tail shaft to crank pulley?
What angle are you trying to achieve?
RileyDymond
18
Ny
Yesterday at 9:02 PM
  • Yesterday at 9:02 PM
No sorry user error 5.2° for both new to this whole angle finder thing zero’d out on pinch weld and frame rail
KRUISR
1,897
1,034
143
Yesterday at 9:11 PM
  • Yesterday at 9:11 PM
Since you didn't say up or down angle, I am going to assume up angle. If you are trying to get that angle lower (flatter), try putting a spacer between the k-member and the frame. Leave the trans crossmember along, only changing the engine k-member.
RileyDymond
18
Ny
Yesterday at 9:15 PM
  • Yesterday at 9:15 PM
Trying to get closer to a 3° angle and yes an up angle sloping down towards the rear
KRUISR
1,897
1,034
143
Yesterday at 9:18 PM
  • Yesterday at 9:18 PM
Try spacer between k-member and frame
RileyDymond
18
Ny
Yesterday at 9:19 PM
  • Yesterday at 9:19 PM
Ok thank you any idea on what thickness would change it 2° or is it a trial and error thing?
KRUISR
1,897
1,034
143
Yesterday at 10:11 PM
#10
  • Yesterday at 10:11 PM
  • #10
You could start by loosing the bolts (not removing, loosening) and insert a section of 1/8" flat bar in the space between the bolts on each side. Tighten them back up and remeasure. See what you get. Based on how much it changed you adjust accordingly (more spacer or less).
RileyDymond
18
Ny
Yesterday at 10:13 PM
#11
  • Yesterday at 10:13 PM
  • #11
Alrighty I’ll try it out tomorrow thank you
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
