Progress Thread Wrong motor angle
So I have an issue where my motor and transmission are definitely sitting at the wrong angle I’m running a tubular k member with stock style motor mounts everything is sitting loose and bottomed out I’ve put an extra spacer (than it calls for) underneath my tranny mount to try and even it out. 5° seems to be awfully steep. Any advice on what to check for. TIA!
Is the rest of the car level? Measure the vertical face of the output shaft/driveshaft yoke. Measure across the balancer/crank pulley. I am not sure if the top of the intake is parallel to the crank centerline, same for bottom of case on trans.
Are those measurements the degrees of the engine up or down from level? How level is the bottom of the pinch welds on the rockers (both sides)? This will give a frame of reference for other measurements - then we can make suggestions.
Reactions: Blackhawkxx
Since you didn't say up or down angle, I am going to assume up angle. If you are trying to get that angle lower (flatter), try putting a spacer between the k-member and the frame. Leave the trans crossmember along, only changing the engine k-member.
What angle are you trying to achieve?
Trying to get closer to a 3° angle and yes an up angle sloping down towards the rear
You could start by loosing the bolts (not removing, loosening) and insert a section of 1/8" flat bar in the space between the bolts on each side. Tighten them back up and remeasure. See what you get. Based on how much it changed you adjust accordingly (more spacer or less).
