what else do i need to get into 12s
i got a 88 mustang with a 95 cobra engine with about 90k
(gt-40 heads 1.7 rockers the cam sounds a bit aggresive idk if its the stock cobra cam) track heat intake mass air conversion with 8ld "california tune" granatelli mass air 75m/w 30 lb injectors bbk fuel regulator stock cobra throttle t-5 tranny future mods 3.73 gears and pulleys
what else do i need to run atleast a high 12
what about shifting 5-6 k ? im thinking of also getting an anderson cam any opinions about them ?
shift point depends on the car, for the cam you cant go too big with those heads, you need to gear it first also. if your mechanicly inclined you can save a lot of money installing them yourself, more than enough $$ to buy a cam.
shift point depends on the car and for the cam you cant go to big with those heads and need to gear it first. if your mechanicly inclined you can save a lot of mone installing the yourself, more than enough $$ to buy a cam.
my cuzns do all the work and dont charge me ... any opinions on any cam according to the mods im running ? what about ptv clearance on that z3o3 i was told f303 was the biggest before notching pistons
f is about as big as i would recommend using stock valvesprings and stock pistons....BUT with that said, dont buy a ford racing cam.
there are MUCH better cams available for the same money. just a personal preference.
look into the TFS-stage 1. 499/510 lift, split duration, IMO its a pretty decent cam for going in a stock motor. others will have their own opinions
do you know if this cam work with 1.7 rockers ? without any ptv issues ?
Get a custom cam...
GT40s, bolt ons, cam, 4.10s and some abusive driving netted my brother an 11.86 @ 114. I think you wanting to go 12s shouldnt be an issue!
damm you must be one hell of a driver ....hopefully it isnt lol one of my buddies was telling me that with what i have right now it would be one the high 13s low 14s im just hopping he is wrong
and about that custom cam ima have to wait on that im going to build a 331 o347 then ill get that custom cam with better heads
