what else do i need to get into 12s
88five-oh
49
eagle pass tx
i got a 88 mustang with a 95 cobra engine with about 90k
(gt-40 heads 1.7 rockers the cam sounds a bit aggresive idk if its the stock cobra cam) track heat intake mass air conversion with 8ld "california tune" granatelli mass air 75m/w 30 lb injectors bbk fuel regulator stock cobra throttle t-5 tranny future mods 3.73 gears and pulleys
what else do i need to run atleast a high 12
  • Sponsors(?)
Tanus
847
A to the Z
what about shifting 5-6 k ? im thinking of also getting an anderson cam any opinions about them ?
shift point depends on the car, for the cam you cant go too big with those heads, you need to gear it first also. if your mechanicly inclined you can save a lot of money installing them yourself, more than enough $$ to buy a cam.
88five-oh
49
eagle pass tx
shift point depends on the car and for the cam you cant go to big with those heads and need to gear it first. if your mechanicly inclined you can save a lot of mone installing the yourself, more than enough $$ to buy a cam.
my cuzns do all the work and dont charge me ... any opinions on any cam according to the mods im running ? what about ptv clearance on that z3o3 i was told f303 was the biggest before notching pistons
tannerc91gt
This last 25% is foreign territory at this point
3,057
234
Indiana
f is about as big as i would recommend using stock valvesprings and stock pistons....BUT with that said, dont buy a ford racing cam.
there are MUCH better cams available for the same money. just a personal preference.
look into the TFS-stage 1. 499/510 lift, split duration, IMO its a pretty decent cam for going in a stock motor. others will have their own opinions
88five-oh
49
eagle pass tx
do you know if this cam work with 1.7 rockers ? without any ptv issues ?
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
35
Montgomery, NY
Get a custom cam...
GT40s, bolt ons, cam, 4.10s and some abusive driving netted my brother an 11.86 @ 114. I think you wanting to go 12s shouldnt be an issue!
88five-oh
49
eagle pass tx
Get a custom cam...
damm you must be one hell of a driver ....hopefully it isnt lol one of my buddies was telling me that with what i have right now it would be one the high 13s low 14s im just hopping he is wrong
and about that custom cam ima have to wait on that im going to build a 331 o347 then ill get that custom cam with better heads
Thread starter Similar threads Forum Replies Date
C For Sale What else is needed to complete my turbo setup? Engine and Power Adder 0
T 2005 Mustang GT - New Injectors, what else needed??? 2005 - 2009 Specific Tech 2
Mstng93SSP Anyone Else Buy Stuff You Don't Need? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 501
Detroiit Anything Else I Might Need? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
stykthyn Anyone Else Have 315's? Need Help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
02 281 GT Installing A Cam: What Else Do You Need To Do? 1994 - 1995 Specific Tech 1
Husky44 Forced Induction Planning Kenne Bell Install-what Else Will I Need? 1994 - 1995 Specific Tech 25
hoopty5.0 What else do I need for my rear suspension? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
musclemustangcb Installing a on3 dual/triple fuel hat with dual super car pumps. What else do I need?.. SN95 4.6L Mustang Tech 5
oz Adding Supercharger - what else will I need? Fox 5.0 Mustang Tech 9
1987stangman wmburns or anyone else, Need some more advice. SN95 4.6L Mustang Tech 2
LarsD Looking at Vortech kits for my Cobra, what else will I need? 1996 - 2004 SN95 Mustang -General/Talk- 22
S Short block; What else do I need for it SN95 4.6L Mustang Tech 1
C What else do I need with this Fox 5.0 Mustang Tech 6
SadbutTrue Holley carb - need gaskets (or anything else) when changing jets/checking floats? Classic Mustang Specific Tech 2
98COBRA281 upgrading injectors, what else is needed? 1996 - 2004 SN95 Mustang -General/Talk- 7
9 Stroker kit what else needed? Fox 5.0 Mustang Tech 11
The Green GT Changing my ball joints, what else do I need? 1994 - 1995 Specific Tech 7
G Flaming River FR1508 - what else is needed? 1994 - 1995 Specific Tech 5
I What else do I need to change the water pump? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
5 what else i need to go cobra all the way 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
9 What else do I need for my Head swap... Fox 5.0 Mustang Tech 9
Tripoli Head Swap - Anything else I need to know? SN95 4.6L Mustang Tech 28
96GTstang46 Need to be in debt with something else.. 1996 - 2004 SN95 Mustang -General/Talk- 8
M Will i need anything else to convert my LX to a GT? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
R So I just picked up some PI heads, what else do I need? 1996 - 2004 SN95 Mustang -General/Talk- 15
The Green GT What else do I need for my fuel press gauge? 1994 - 1995 Specific Tech 7
Z What else do I need for a Fox TB Swap? 1994 - 1995 Specific Tech 2
M Getting 347, What else will i need? 1994 - 1995 Specific Tech 8
F What else do i need??? 1994 - 1995 Specific Tech 0
S What else would I need? Classic Mustang Specific Tech 7
95Vert Does my car need a tune, Don and everybody else? 1994 - 1995 Specific Tech 14
J What else do i need 1996 - 2004 SN95 Mustang -General/Talk- 1
G King Cobra kit...do i need anything else? 1994 - 1995 Specific Tech 2
QUICK91LX H/C/I Combo...what else will I need? Fox 5.0 Mustang Tech 8
Nopantz Zex Kit...what else do I need Fox 5.0 Mustang Tech 4
HoustonGT Time for Nitrous, What else will i need? SN95 4.6L Mustang Tech 2
90_Red_LX AFRS are here, what else do I need for the motor? Fox 5.0 Mustang Tech 6
nonglossjason anyone else got the need for speed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
68torinogt what else is needed? Fox 5.0 Mustang Tech 9
steveb24 anything else needed? 1996 - 2004 SN95 Mustang -General/Talk- 8
Repostyle Anything else I need? Fox 5.0 Mustang Tech 2
PacificStang46 What else is needed??? SN95 4.6L Mustang Tech 2
The Green GT If I buy wheel spacers, what else do I need? 1994 - 1995 Specific Tech 10
K How much for clutch/flywheel install what else do i need? SN95 4.6L Mustang Tech 10
The Green GT What else do I need to get when I order my gear? 1994 - 1995 Specific Tech 4
TheDamned Gear install, anything else needed ? 1994 - 1995 Specific Tech 35
B will this work, what else do i need Fox 5.0 Mustang Tech 1
A What else do I need to bolt this puppy together Fox 5.0 Mustang Tech 5
RsStanG1987 What else do i need? Fox 5.0 Mustang Tech 16
