This build will start out slow with some small changes along the way hoping to eventually get a little crazy with it down the road. Bought this 1992 LX 5.0 w/5 speed sunroof car with some mods on it already. from what I've been told by PO and found on it so far is
-4.10 gears
-Ford racing valve covers
-MSD Blaster coil
-pro5.0 tower of power shift kit
-UPR trick shift stick
-aluminum driveshaft
-Ford Racing shorty headers
-bbk catted h pipe-CHANGED to Bassani offroad X-pipe
-flowmaster american thunder cat back
-Eibach lowering springs
-led smoked tails
-smoked headlights and corners
-CAI in fender, not sure of brand
-Cobra upper and lower intake manifold
-75mm Accufab throttle body
-under drive pulley kit, I know take that crap off
-PA performance alternator
-autometer gauges
-rear control arms, unsure of brand
-sub-frame connectors, unsure of brand
-Saleen replica wheels, 4 lugs
-Its been repainted at some point. decent job, not bad but not perfect.
-Cobra front grille
-134A AC conversion
plans are to get the car straightened out. it needs some TLC and brought up to my standards. once thats done it will be time for some go fast parts.
ADDED
-Maximum motorsports caster/camber plates
-i recently scored a deal on a black painted cobra R hood and installed it. also replaced a faulty ignition switch and fixed some other little issues.
-70mm MAF
-SVE in the fender CAI
-sun roof gasket
-hatch gasket
-Ford Racing Harmonic balancer
-Bassani off road X-pipe
-Procar by Scat Sport seats
-Cup holders in center console
-LED dash/cluster bulbs
-Carbon traction Lok discs
-Ford Racing diff cover
-4 gauge power wire upgrade
-stock pulleys back on
-new pinion flange
-rear got all new bearings, races, and seals
on to some pics
the day i brought her home
-4.10 gears
-MSD Blaster coil
-led smoked tails
-autometer gauges
-Cobra front grille
-134A AC conversion
ADDED
-70mm MAF
-sun roof gasket
-hatch gasket
-new pinion flange
on to some pics
Of course not the LEDs you knit-wit!
