What for today? Lots of little stuff. Lots of pictures of lots of little stuff too.
First picture is of three parts that had broken off pieces. One part is right side interior windshield trim. Repair area in red circle. Second part is the left exterior mirror trim. Repair area in red circle the green circle on that part and the right mirror trim are areas that are broken off and missing. The piece is supposed to go completely to the top of the trim piece.
I did my usual plastic repair, I sanded the areas with 80grit, made some deep scoring with a die grinder with a cut off wheel. Rigged up the pieces to hold straight and in place. I used the dry wall mesh tape for reinforcement, sprayed adhesion promoter and broke out the PBA.
I used a rivet to maintain the location of the rivet hole right where it needed to be. The piece was broken right through that hole. I removed the rivet after about three hours while the PBA was still somewhat soft, but not flow able anymore.
On the trim pieces where the broken off piece is missing, i made a quick little form using masking tape and various things to support the part in the proper orientation and ran a bead of PBA. I'll need to do a little carving to make it look and fit like it did when it was new.
