Honestly Chris, I just want the scoop for now. Like what Nick @95BlueStallion has plans for with his car. I'll two sided tape it to the hood. Obviously paint it the trim grey and finish it in the satin clear.That GT hood is going to look killer Dave.. Will it be getting the same stripe/lettering treatment as the other hood?
You're "The Mechanic"!Very nice score !!!
If you're the junk man, who am I ?![]()
The hood will get stored until Roby is driving and I have a couple spare nickels to rub together. Should I send it to the guys that blasted the first hood?
At that stage as I build up the parts for the new drivetrain I'll get it media blasted, repair it, then set it aside in storage till the day that Roby has the opportunity to be a badass.
Sounds good Dave,Roby is going to turn out great.
The car you're getting the hood from-does it have the drivetrain still intact?
Just thinking out loud dave,that if you are going to rebuild an engine and trans.. Might as well be the engine and trans you wantYes it does..........hum.......yes it does.
He does not want a non-roller block 5.0...and the chicken peen sized exhaust ports that go with that.Just thinking out loud dave,that if you are going to rebuild an engine and trans.. Might as well be the engine and trans you want![]()
That is unless you plan to have to add Zinc enhancers to keep the flat tappet cam alive Dave? Or convert it over to a retro roller.
BTW....80 bucks! That's right $80 for the hood and scoop!![]()
Bwaahaahaahaahaa!Just a suggestion for your nicely painted hood... They make good wall art. Observe exhibit A; my stock '11 hood I cut into a heat extractor, but never finished.
If I could Mike, I would. I need a nice long road trip.Dave drive to MA and you can have my GT40Ps.
Sure you'll prob spend more than what they are worth in gas....but road trip!
That's what I'm thinking Joe, 351 clearance. Someday. Right now? Just to pretend i'm breaking bad.Hood with bubble scoop... extra clearance for a carb or maybe a 351...Humm...
It's weird you sleep with a madmike doll ^^That's what I'm thinking Joe, 351 clearance. Someday. Right now? Just to pretend i'm breaking bad.![]()
As of this post, i have offiJust a suggestion for your nicely painted hood... They make good wall art. Observe exhibit A; my stock '11 hood I cut into a heat extractor, but never finished.
Well,..At least you got the doll for now.That's what I'm thinking Joe, 351 clearance. Someday. Right now? Just to pretend i'm breaking bad.![]()
Can you change him out of his chemical suit and put him in the jacket and fedora?I don't sleep with the doll......It's weird you sleep with a madmike doll ^^![]()
