Actually Mike, i'm going to list it on Facebook this weekend. I don't like the site, but if it helps move out some of the extra stuff, I'll give it a go.What you ever do with the 3.8 S/C? Worth selling off to recoup some cost?
Ok, let's forget the mini-tub idea just for a moment.
IRS upper and lower control arms, couldn't I really just make my own? I have a nice flat metal table I could weld a jig on.
If I were to copy the stock locations for everything, just use tubes instead of that monster aluminum lower, do you think that would still be problematic?It's not just making control arms, but also redesigning how the wheel travels through its arc and shock/spring mounts and rates. A bit more complex.
Why not a little extra body work like matt Farrah's notch?
Hey Chris @FastDriver ,you’re one of those super smart engineer guys.
Let’s say I could shorten (or find shorter than stock) the half shafts about 2”. Then I make a new set of control arms to bring it all together. What might be a problem with geometry changes?
Hummmmm........that Griggs article is interesting.That's very kind of you to say, and I'm very impressed that you're even considering fabricating your own suspension. I'm sorry to say that this sort of thing is outside of my wheelhouse, though I like soaking up the experience of others. I'll just throw in a couple of observations that I haven't seen already addressed. What you've put forth should work, but if the differential housing to the wheel hub center is not in line, then shortening the rear track increases the angles of the CV joints to compensate for the offset. I would measure/calculate the range of possible angles and ensure they are well within the CV joint limits. A quick search turned up CV joint types and common limits: http://www.gknservice.com/gb/passenger_cars/constant_velocity_joints.html
From what I've read on the subject of improving fox handling, the big players spend a lot of time trying to eliminate the understeer, meaning that it's the front suspension and tire that needs the most improvement. And, before you entirely convince yourself that IRS is the way to go, I'd encourage you to read this from Bruce Griggs: http://www.griggsracing.com/pdfFiles/IRS vs Stick Axle Debate.pdf
Though it would be pretty awesome to see someone customize their own suspension, my gut says it will be be chalk full of unforeseen issues, less effective than off the shelf systems, very time consuming, and ultimately more expensive. So, the coolness of doing it yourself and the props from us on your fab skills are the only upside I see.
With a hard tail mount you should be able to easily run 10"/10.5 wide wheels. @hoyster Have you done any measurements to confirm wheel width on a hard tail IRS?
How freakin' cool is this^^^^^ a road race Mustang wearing Monster colors? I'm thinkin I like the satin paint line going over the roof.I haven't done any official measurements yet, but the inner fender is now the limiting factor as the mount now sits slightly inside that.
And Dave, just for your reference, this is what I am doing (though more polished and not quite as racy looking). I will be blending the rear quarter panels into the bodywork instead of riveting them to the body. With the fender flairs and hard tail mount, I can fit a 335 in the rear, though I will probably run a 315 to match my front. My front end will be a MM based road race setup with 1.5" forward offset control arms, with the matching fender flares. The front end of the mustang suspension is really where you have to pay the most attention, for handling purposes that is.
Dave.....Plane ticket time?
IMO Griggs is an IRS hater. He doesn't want to compete against MM and FTBR with R&D of products to upgrade the Cobra IRS. It's also not a huge market since there's not an abundance of desirable 03' & 04' Cobra IRS units. There's a sh*t ton of 8.8 SRA's though and they work well on the track and that's been proven time and time again. If you talk to anyone from Maximum Motorsports or even read the tech info from Bruce at Full Tilt Boogie Racing you'll find that they love both and either design has their strengths and weaknesses.Hummmmm........that Griggs article is interesting.
Got to admit, tubbing would be far easier with an SRA.
