It’s the oil pan, rear sump......though I got to admit, those red caps are pretty hotGood call. Those red plastic caps make all the difference.![]()
Does that seat last?
I bought their other seat, and the damn threading on the wheels stripped out causing me to fall on my ass.
http://www.hfqpdb.com/coupons/993_ITEM_MECHANIC_S_ROLLER_SEAT_1430488162.5911.jpg
Wait for the sale, $20.I had to get a new heat gun yesterday and got a COUPON for $8.99. The previous one had been pretty good and I used the hell out of it on my rewiring, but the other day, it seemed to kick in to afterburner. The fan sounded like it revved up 2 or 3 times faster and there was a plasma arc inside. Within seconds the motor seemed to experience catastrophic failure and the thing almost caught on fire! BUT, for 4 or 5 years with some heavy use in the last 2 months, I will say that was $8.99 well spent because I am sure I had a coupon for the first one!
Let us know how those lights work out. I looked at that yesterday but couldn't pull the trigger. Need a coupon!
$20 sake? Too rich for my blood. I prefer the hot house sake, especially the early bird special 2 for 1. Get 2 house rolls and soup for $9.99 too.
I think I get the going overboard on a mustang thing.......Now you know how putting seatbelts in my 70 Mach 1 turned into a dash torn down to the firewall.
I think I get the going overboard on a mustang thing.......![]()
My case wasn't going overboard, it was, "While I'm here I should...", like your bathroom.I think I get the going overboard on a mustang thing.......![]()
Ah! I understand. Funny how that happens a lot with me too.My case wasn't going overboard, it was, "While I'm here I should...", like your bathroom.
Hummmm.......you got me reading.Hey, I see our using the Por-15.... are you using there metal ready first? por-15 doesn't like new/clean metal... it will come off.... thats the one thing I don't like about that product, you need to keep it wet with that stuff for like 15min, then wash it off real good...(which makes a mess of course) now you have to dry it, and then paint the por-15t on...
I just bought a qt of this stuff new from eastwood - https://www.eastwood.com/eastwood-rust-encapsulator-platinum.html I just tried it this weekend, blasted under the car and painted this on any area's I removed any rust or had bare metal.(most of the middle section still had the undercoating on... so if the blaster didn't take it off when passing over, I left it) this needs less prep, just wipe down with pre (any wax/grease remover) and brush on... then next day I sprayed Epoxy primer, then day after I sprayed black paint... this weekend I will spray the POR-15 bedliner on, and complete the painting of the underside of car.
It does need an etch. The prep stuff they use is just plain old metal prep we use periodically at the shop. They make it sound fancy though.
I’ve used it mainly on painted surfaces in the past. So no issues there. This really is the first bare metal application I’ve been using it on.
Guess I’ll metal prep the other side prior to application now! Luckily most of the metal I’m using I coated with an etching paint in the first place.
Thanks for pointing that out.
The Eastwood stuff may be good, but I got the POR15 for free, sooo......
