- Jul 7, 2005
- 1,563
- 1,197
- 164
Looks like you are getting the hang of it. Keep up the good work
Words of wisdom...
Datalog...datalog...datalog...
These are your best tools to updating the tune as they tell you everything that is going on.
This is one of the main reasons for the latest update to my digital dash to automate the starting and stopping of the datalog for me. All I do now is start/stop the engine and the dash does the rest for me.
Also, the longer the datalog the better , but just drive softly for your first drive. This will help tune in your part throttle area, which is the main area you are in while driving anyways.
I mean if you insist....
i think my Intake sensor got heat soaked and is causing me to have lean starts while hot.. cause for some reason my hot starts .. start up fine then 4 seconds into it it starts surging. i had to hold the gas to calm it down.. so its either going lean.. or not enough air. my feeling is its going lean.. all i know is i gotta figure it out.. haha
If it only happens on hot start look at the enrichments. You can also disable the mat correction at startup in the main idle settings
thanks, I appreciate the patronage
