Haha! Oil pan and headers!Its a pretty straight forward swap, as long as you have correct oil pan and headers.
Yeah! I know. I am actually past the 351 swap point. Now it’s all about the refinement!Its a pretty straight forward swap, as long as you have correct oil pan and headers.
Oh Haha, my badYeah! I know. I am actually past the 351 swap point. Now it’s all about the refinement!
Well it’s almost a year ago that I posted that. Gonna scratch off 2 and 4. I really want 1, 3, and 5 now. If I can find a t56 that would be awesome. A higher compression shortblock that I can still run 87 octane in would be fantastic. And clean new paint on a straight body would be the cherry on top!! I’m gonna put a new list up.My list tentatively is
1. 6 speed
2. cobra r brakes
3. long rod 351w (I don’t care, I’m gonna try it.)
4. hood scoop (the engine is currently rubbing against the banged up hood)
5. overall cosmetic restoration
a. paint
b. dinoc woodgrain
c. repair any dents in metal or trim
d. hydro dip woodgrain graphic on
outline wood trim pieces.
There is a lot more but the rest of it is just day to day type stuff. God willing the Daddywagon will continue on it’s current path to greatness! Haha!
Where are you located. I know a place that has f4te blocks for $150Assuming the 3/4 spacer does the trick for my brembo brakes here are my current wants. I have some of what I want on my list but I have yet to install.
1. 6 speed manual transmission
2. engine rebuild (long rod)
a. Keith Black KB333 pistons .030
b. Ford 400M 6.580” connecting rods
c. Ford Street Cruiser x2 heads
d. F4TE casting roller cam block
e. Stock 86-88 speed density roller camshaft
f. Cobra roller rockers
3. full fox mustang dash and console with
working gauges including 140mph speedo
4. air conditioning
5. cruise control
6. horn
7. full cosmetic restoration
8. 79 pace car recaros upholstered to match
I could probably keep going if I think hard enough, but lets start there.
I am located in Levittown, Pa. but at this moment I do not need a block. I have most of what I need for that engine build already. I have block, crank, rods, and pistons, and camshaft. I just have to get all the machine work done then assemble.Where are you located. I know a place that has f4te blocks for $150
If they aren't already on your shelf, you need o change your wish list to NOT include Keith Black hyper u craptic pistons.....Assuming the 3/4 spacer does the trick for my brembo brakes here are my current wants. I have some of what I want on my list but I have yet to install.
4. air conditioning
5. cruise control
6. horn
Aaargh! Well I already dropped the coin on these so I have no choice but to roll the dice! I will try to heed your warnings though and be as vigilant as possible regarding tolerances, etc.If they aren't already on your shelf, you need o change your wish list to NOT include Keith Black hyper u craptic pistons.....
Lest this be a future picture that you provide for us..
Read the reviews.... ( if you can find them...people don't buy these things) The problem with these Pistons is they do not tolerate an incorrect ring end gap, and the rings butt, and cause the failure that you see above. Read the recommended ring end gap chart.....get them too loose because you " intend" to use a power adder, and the engine will use or spew oil...put them too tight and....oops...ka blooey!
They're cheap because they're cast, and they're crap. ( this " review" comes from my usage of them, )
Pistons that are forged, but have added silicone like a JE, and a dozen others are very affordable as a better alternative. The alloy is listed as 4032/36. That piston shares the same potential benefit as a hypereutectic ( less thermal expansion from heat, which allows the machine shop to run tighter skirt clearances when finish honing the bores..which equates to less piston noise) While at the same time, affording a degree of softness to allow the piston to " forgive" pinging/detonation without shattering should something go wrong with your tune.
I doubt the Cobra springs will do you much good. What shocks/struts do you have front and back? Do you feel that the harsh ride is due to the front suspension setup or front and rear? How are your bushings?The Daddywagon sits quite low and handles good. The ride is harsh. Up front is B springs. Out back are stock 2004 Cobra IRS springs. When I bought the IRS the seller gave me the stock front Cobra springs. I am gonna install the Cobra springs up front and see what they do.
