Fox Steering Wheel Thread
Looked to easy to not try to make own.Started with a cardboard template then transferred to 18 gauge steel,hour or so later had a working cruise button mount.Hardest part was coming up with a way to mount the switches but wasn't too bad.
my
What size, 330 or 350 mm, is that? And why did you chose that specific thickness?
I chose the 350mm to stay close to the size of the stock wheel.I thought the smaller size might look odd and block my view of the gauges.
I love the feel of the suede wheel in my hands.I've had plenty of DD with leather wheels,and unless they're perforated I find in short time they become way too slick.
I got mine from advanced Auto parts, and simply returned the stock fox rack that was covered in grime and the guy didn't care... just said cool and gave me my core. HUGE upgrade in steering feel.
Did you purchase it online or do a local pickup? I called my local Advanced Auto Parts and they have a inventory of zero.
The only place that seems to have them in stock is Amazon at $440.
Is this the wheel and hub you have? (minus this one being 320mm instead of 350) If so, I'm thinking I might go pick them up tomorrow and get a better wheel to match my new seats that I'm still waiting on the tracks for.
Yup, those are what I have.
If you want the ford horn button, here’s that part
I just checked, seems the source of racks is drying up. Even eBay had none, which is strange.
Guess returning fox racks as cores leaves nothing able to be rebuilt
Alright, f it! I pulled the plug and bought the only remaining Cardone 20-2000 I could find online. Seems silly to do all this work to my car to retain sloppy steering. I can always return it through Amazon. Yes, I just justified the purchase twice in one paragraph.
I got my two and half turn at Advanced for $70.00 25 % off . Leave it in your cart. If your a member after a day they e-mail a 25% coupon . Let me say again . Unbelievable feel with supplied bushings....Also get a filter they say its needed. IMG_0238.jpg
Did you buy yours months/years ago? They don't seem to be available anymore unless you bought a non Cardone one. Do you have a part number or a screen shot. I'm not excited about dropping the $400+ on Amazon, but there doesn't seem to be anywhere else to buy one unless I pester all the Southeast Mustang salvage yards.
You undo the return hose at or under the radiator and pour a quart or two of Mercon into the pump . Turn the pump by hand and it runs all the old fluid and dirt out. Then add a P steering filter on the return line. Now your new.
I'll probably install a new power steering pump as my old one is shot (numerous leaks) and I don't like to deal with problems a second time.
I'm planning all new steering rack, outer tie rods, power steering pump and even a new steering column with MOMO steering wheel. This will be similar to my 5 lug '03 Terminator brake swap out.
