Ah... I thought you were trying to keep the OEM ones.New stainless T-bolt clamps
Doing fine, thanks for asking. I'm a long time lurker here, but I post a bit on The Corral with the same user name. I stop in more often now to check on Mustang 5L5's build thread.
soak them in 303 and they will be like newRad hoses came in.
I’ve said it before, but I’m just not thrilled with the quality of Motorcraft parts for our fox bodies these days. They seem cheap.
New Motorcraft replacement vs either my oem hose.
Actually, I may have replaced this hose in the late 90s. I seem to remember doing so but it still has the stapled on oem hose clamps. Also shows an E7 part number so maybe it is original
I’m almost tempted to just reused the old hose. It looks better, lacks the cheap corrugated crap, and feels just as pliable.
Waiting on my fan stuff now
For the nipple, isn't it already hooked up to your intake in post 863? Keep it where it is supposed to be.Just remembered this. What to do about it?
I don’t want to remove this pipe. I don’t want a repro without it.
Good choice on the Contour fans. Are you going to run them dual speed or just high speed? If you are interested in running the factory overflow, it does fit between Contour fans and PS/AC pulleys, I have been running mine this way for 4 years now (3 core OE style rad).
If you are going to run a MS3 why not just use a dorman 902-310 relay? it will allow you to setup a PWM circuit right from the ECU without the need of a separate controller
it can even brew a decent cup of coffeeWhy add a second controller that could fail? I have every system tied into my ms3pro it can do nearly anything I can think of.
The Derale PWM controllers are actually DCC controllers that were widely used and loved years ago.. They partnered with Brian Baskin a few years back so they would be a solid choiceI haven't decided on the fan controller for the fans just yet. Doing a lot of Youtube video watching right now, but I am liking the Derale PWM controller.
I used a few of the DCC controllers back in the day but grew tired of the terrible customer service and wait times, so I went with the FAL VSC's and never looked back. The reviews on the Derale PWM's are mixed as an FYI.The Derale PWM controllers are actually DCC controllers that were widely used and loved years ago.. They partnered with Brian Baskin a few years back so they would be a solid choice
