I went with mrt, on my car I found it pushed the hood forward slightly. Took some time to adjust, but I'm happy with them.
Stock steel hood as well on a 93 with mm c&c plates.
Thanks i was wondering how they fit with MM plates
I have the redline hood struts on mine. I will say, take their warning seriously about drilling the holes in the underside of the hood. If that bit grabs and pulls through it will ding the hood from the underside and it will be VERY visible from the top (shiny side). Yes, I admit this happened to me but fortunately it was a spare hood I had, and not the actual vin'ed hood I put back on the coupe. When I did my actual hood I wrapped a ton of tape around the bit so it couldn't get pulled through.
We need a pic that’s zoomed out a bit to make judgement on the bolts.
It’s sunny, calm and a beautiful 7 deg day.It is supposed to hit us here around noon to 1:00.
We are expecting 18-24" with winds of up to 55 mph.
Since it is only 5*F now, I expect most of this stuff to just blow around and create drifts.
It is going to be a challenge to keep the driveway plowed. I have about 400' out to the road to keep clear.
Just turned on the AC...February thaw. Massachusetts will get their thaw soon. Two to three weeks, and your off for a quicky.We got about 11" total, but the snow was so small and light that the wind made lots of drifts up over 3' high.
Today it was 45*F today and rain.
Supposed to get 8-12" tomorrow. We shall see.
did the same, no problemo.I have the redline hood struts on mine. I will say, take their warning seriously about drilling the holes in the underside of the hood. If that bit grabs and pulls through it will ding the hood from the underside and it will be VERY visible from the top (shiny side). Yes, I admit this happened to me but fortunately it was a spare hood I had, and not the actual vin'ed hood I put back on the coupe. When I did my actual hood I wrapped a ton of tape around the bit so it couldn't get pulled through.
I used them on the last car and they were good. I need to get another set.I think i'm going to go with the MRT struts here. I like the idea of no-drilling and able to undo the mod later on if i don't like it.
Yes, I want to see the fit... unfortunately I run a fiberglass hood, not sure I can get away with hood struts.I think i'm going to go with the MRT struts here. I like the idea of no-drilling and able to undo the mod later on if i don't like it.
