Electrical what speed sensor eletrical wire is for?
Wow really . They put a 87 ecu in a 89 or its not a real 89
So it’s entirely possible your ‘89 has been swapped to a speed density setup.
To answer your initial question, the VSS is not used at all with speed density other than with cruise control.
As to why the car has been swapped, someone probably did some hackery in the past maybe using a donor 87-88 and a roller 1989. Wouldn’t surprise me
On your VIN, the 5th to 7th digits are P4x, what number is the x?
After those three there is a letter, what is it? If it is an E the car was born with a 5.0, if it is an A then you have a 4 cylinder car someone did a 5.0 speed density swap.
No real reason to purposely do it.
In stock form the speed density cars run a bit stronger, however they are very sensitive to vacuum leaks and your hands are tied when it comes to cam swaps.
You could easily convert to mass air. Here are harness kits available
That's a broad question to answer. Ford made small changes in the harnesses year by year so that they don't really interchange with each other. It's not a speed density harness vs mass air, but rather 1990 harness, 1991 harness, etc.
Some of the individual wires route differently. For the most part if you want to swap to mass air you'll need a conversion harness, and also pay attention to the O2 sensor jumper pinout
