New wheel that I’m going to use as my spare tire showed up. Racestar Recluse 18x5.
Miles of clearance on brakes. Now to mount up the spare tire. Went with a 145/70/18. It’s supposed to use a 4.5” rim but I think I should be ok.
Not a bad looking wheel. It's got a little weight to it though.
June 11th, the formally known as Ashley Ford (now Empire) show is at UMass Dartmouth, any chance the car will be there?
I went ES 12 A . been a couple of years and living in the oven called Nevada it works great,cost less, oh and its enviormentally safer. Todays temp is 102* but im cool.Done.
So weird to sit in my car on a humid 80 degree day in AC. Normally I’m sweating my butt off.
Last time the AC worked was when I was 17ish. Used it a few times late summer/fall and it might have needed a recharge but it took the edge off.
Then I decided that I needed to go 0.05 seconds faster so I ripped it all off. Stupid me.
I have to say, total PITA doing this with R12. If I had to start all over from scratch, given what I’ve learned I just would have gone R134a.
That is what I used as wellI went ES 12 A . been a couple of years and living in the oven called Nevada it works great,cost less, oh and its enviormentally safer. Todays temp is 102* but im cool.
yes flammable like gasoline only a much higher ignition point.Isn’t that stuff a hydrocarbon refrigerant and flammable?
