- Oct 21, 2006
- 524
- 43
- 49
Yeah that engine looks decent! 4 bolt even! Would I be able to run factory computer EFI? I would have to go up to 30lb. injectors and a calibrated MAF. I was looking, Pro-M only had for fender wall CAI. I'm running stock air box, that's pretty much the same right? It is a fenderwall cold? I would like to use my Edelbrock Performer 5.0 EFI intake. Blueprint recommends carbureted. Swap the pan. Blueprint is rear sump. Will that work with my pan? Then I would have to go to a V-belt conversion. The kit on Blueprint Engines is $1,100.00 yikes!Looks like blueprint finaly updated there site. But for what most shops are asking for long blocks these day I would probably pull the pin on this one if you just after the performance of the old frpp engine... There aluminum heads and new aftermarket 4 bolt block for $5k and a decent warranty. Swap you pan, front cover and every thing else over.... Keep you old engine, parts from it are worth a decent amount
Ford Small Block Compatible 302 c.i. Engine - 361 Horsepower - Long Block - Rear Sump
BluePrint Engines Ford small block compatible 302 c.i. crate engine - 361 HP - Long block. Includes 30 month/ 50,000 mile warranty and BluePrint Dyno Promise. Part #: BP302RCTblueprintengines.com
Thanks for the help!
