Progress Thread Project: Buried Under A Mountain Of Snow Black Hole Money Pit.
What are you hiding?
Reactions: General karthief
You don't see them very often but when you do know it. You seriously need to show off that valve train if you have on there what I think you do...
Dunno...
But the heads are all stripped down now to make my valve springs work. Definitely gotta change some stuff around to get the correct install height and correct distance from coil bind
While one project is down... a little focus on the other one
6L LQ4 I gotta go pick it up here soon get it stripped and cleaned up. Then I can make a list of everything I need for it. Plan is for over 500 NA. It's gotta at least make somewhere near what the superduty makes, which is turned WAY up now lol
The 408" is still down at roche racing engines so I've been working on the LS still
Cam is ordered its a richard holdener unit, did BTR springs with titanium goodness. Still need to order an oil pump and some other stuff.
Also found the car needs floor pans.
So thats where we are with that.
