I got the car back from the painter a couple of weeks ago. I have been slowly putting it back together. When the car was at the painter's the battery went dead a couple times. I thought the hatch may not have been closed all the way and an interior light was on and drained the battery. I put the battery charger on it overnight on a 2 amp charge when I got the car back to my house. It started the next day after being on the charger. A couple days later I went to start the car and the battery was dead again. I put the battery in my other '88 to see if the issue was the battery or something to do with the car. I drove the other car around with the battery in it, everything was fine. A couple days later go out to start the other car and the battery was dead.
We thought it might have been the sunvisor lights causing the battery to die so I pulled that fuse. I bought a new battery since the other one wouldn't hold a charge. I put it in the car that just got the paint job. Everything seemed good. This weekend, a couple weeks after installing the new battery, I went to install new window run channel weatherstripping and the new battery was completely dead.
Is there anything common on these cars that causes a battery draw? Everything is pretty much stock besides an aftermarket radio. I'm pretty sure the radio is on the same fuse that I removed for the sunvisor lights. Prior to installing the new battery I had removed the dome light bulb. The light for the cargo / hatch area was removed from the car when we disassembled the car a few months ago.
Anyone have any ideas on what I should look at or how I go about finding the source of the draw?
