66 Coupe Progress Thread
I allow images, tune files, pdf files, and a host of others but [not] do video files.
The files themselves are not the issue. Serving/Streaming those files over the internet is something we're not setup to do.
Youtube is setup to serve video files. Host it there and post the link here. Some people even upload to their Bookface account and post link from there. Whatever works best for you.
Reactions: Mcmahst
View: https://youtube.com/shorts/NzIPlFAVzcs?feature=share
Any chance that you could contact the PO and ask him why he put a vacuum pump on the car? I’m just wondering if he installed the engine and then realized he had such low vacuum that he wasn’t getting the break performance that he wanted or expected and he added the pump instead of chasing down the vacuum problem. I think that vacuum is too low at idle. The throttling and changes in vacuum look completely normal with the exception of the vacuum at idle. Just a set of hunches, but first and likely a vacuum leak in the base gasket of the carb, a hidden hole in a vacuum hose, and intake manifold gasket. Next potential problems, and this goes back to to my first question. Intake valves with too much preload, causing a very slight leak.
Did you verify initial timing and total all-in timing? Good luck.
Don't look at the vacuum reading alone, the needle action shows an issue, the needle should be steady at idle unless you have a cam with a lot of overlap,
first adjust the timing to get the highest vacuum reading, you will likely have to adjust the idle too, make your timing adjustments with the vacuum advance disconnected and plugged.
can you get a steady vacuum needle by doing this?
Reactions: DadLife0724
From your first post, I suspected the problem might be cam timing. You said you have consistent 135-140psi in the compression test. That sounds low to me, especially for a new engine. 165/175 would be my expectations. So, if it is a new engine, and you have low vacuum at idle, and low compression, cam timing would be the first place I would verify. A performance cam usually creates low idle vacuum due to the overlap. But you don’t usually see these cams on engines with low compression, like 8:1 or something around that. If you’ve run out of likely causes, then cam timing becomes more likely; at least likely enough to run it to ground. Good luck.
I'm gonna jump back in this week. Timing is set to 12 deg advanced to 33deg.at throttle. dont know the rpms as no tach,auto trans. I will check everything....timing again, fuel pressure (going to install a regulator setup), bowl float levels, mixture screws, etc. Will remove and clean plugs first and work through everything. The one thing I'm not sure about is that the carb is black from running so rich for so long. Best way to clean it?? Thanks for any input you may have.
Also I want to reroute the gas line to the rear of the motor (Firewall area or brackets on motor or valve cover bolts) as i am going to clean up the front topside of the motor. Should I make metal lines to mount on the "Body" (or motor) and then rubber gas line from the mechanical fuel pump to said line and then rubber lines from said line to carb filter/regulator setup?
You can run a rubber line from FP to the frame rail/fender apron area to a hard line mounted with those nice isolated line clamps, with a bend at the firewall, then a rubber line from the firewall to the carb
Thats what I was thinking. currently just have it connected with the rubber hose from the regulator to the carb. when I get around to it ill do the hard mount.
working out the timing and float levels, mixture screws etc. I think ( my problem) Im getting close with what little knowledge I've learned on this forum. Its running pretty good .....but a new problem has arisen in that the electric radiator fan shuts off after the motor heats up. It has a 175/185 fan sensor (mounted in the water neck) with a 185 open thermostat. I have jumped the fan control relay to be on all the time and it still shuts off after driving a while. Is there an overheat sensor in the SPAL 16" fan? Dont know why it would shut off when jumpered always on .
pulled plugs and they are covered with carbon build up, but they are dry, no fuel. Carb is also black with carbon buildup so Im assuming ( you know what that means) the pistons have carbon buildup. Stupid question......is there any way to use carb cleaner while the car is running to clean the carb and piston tops? or will that just make a messsss? or cause more problems?
When I checked the fuel mixture screws, the secondary screws were closed. Primaries are about 1 1/2 turns out with fuel level in sight glass on both about 3/16 from bottom. Pressure regulator is at about 6 PSI
