If that air damn can take curb, then I like it.
Probably the fastest mustang two in the world for this week.
Score an extra point.
Our Hero extra_stout!
It sits under the radiator support on my 86 so.... Don't park on the sidewalk.
You know... I like to experiment, but I also like to be alive.Cut, shape, and fit something like this to the front of the car to help cut air beneath the car:
You know... I like to experiment, but I also like to be alive.![]()
Something about parking on the sidewalk?Ok... How does that apply?
I do not want to experiment with aerodynamics... or with parking on sidewalks.On the 1gen Mustang race car drivers had problem with aerodynamics beginning at 140 MPH... in a way that the hood did act like a wing and the car did get light at the front wheels. I don't want to experience that.
My tacho conversion seems to work. A friend helped me with RPM reading with my ignition light and comparing it to the modified tacho... at night, because it is much easier at daylight.
I will post some pictures how I did the conversion. Its not more than 100 RPM off from idle up to 4000 RPM. That works for me.
- burn the whole fuel tank nearly empty to get new fuel into it before wheater is getting bad=> 650 Ohm resistor
- tacho conversion from 6 to 8 cylinders
- installation of new used fuel level and water temp gauge (the old ones get stuck, the new used ones worked fine in a bench test)
- reverse light is not working; look up where the error is
- maintanance
Things I want to do, but will more likely a thing for next year (hopefully):
- remove DB killers from exhaust (measure before and after to see if it is nearly legal)
- install new u-joints on driveshaft (+ paint); check drive line angles
- custom adjustable front sway bar
- wheels?!
A front air dam is hardly "experimenting"I do not want to experiment with aerodynamics... or with parking on sidewalks.
Drove just little more than 1000 miles in the last two years...
Looks like the resistor goes in the red wire: https://stangnet.com/mustang-forums/threads/tachometer-conversion-from-6-to-8-cylinder-will-also-work-for-4-to-6-or-4-to-8-but-with-different-resistor-size.924607/#:~:text=The conversion works only from lower cylinder,shows with a V8 following RPM: RPMv6tacho=8/6*RPMreal."- tacho conversion from 6 to 8 cylinders=> 650 Ohm resistor"
Where did you install this resistor?
The Wifey is gonna love it.And!!! I Picked Up my new "old" car/nugget.
She does and me too. It's a light nugget. It has TI VCT (V-TEC) that kicks in at around 3500 to 4000 RPM. Its so funny. Did get a new cam drive belt cleaned the magnetic valves for the TI VCT cam, which they didn't need, whats a good sign. Played a little with tire pressure. It's a pocket rocket...The Wifey is gonna love it.
I was right: one spark wire connector was off and one loose. both near the battery bracket I was working on lately. So I think they did get loose and I didn't notice.But perhaps it's my past me hiding some easter eggs...
