Rim suggestions
mason5.0
11
Mass
Building a 92 lx painting it reef blue.
Cars still gonna be street driven but i want a fat side wall for the rear on a budget(15in rear) 265-285 and preferable a 225-255 front on a 17 in rim.
Rims must match
Also 5 lug converted foxbody kength rear axels
Im also considering 17 in all the way around with like a 275/40/17.
Not to into the 90's look but ill hear you guys out im thinking of some ds08's but not sure how they would look with a fat side wall
A 275/60/15 will fit in the rear with a 6.5" backspace
Need to remove the quad shocks.
Would not hurt to roll the rear fender lip, but don't have to if the rear fender is not sitting down close to the tire.
Got any images of your car? :O_o:
:worthlesb
I like these:
:jester:
What’s your budget because we can go from OEM wheels to some forged two piece wheels that are worth more than the car. What brakes are you goi g to run?
It's just the body right now lol cars being fully restored but Im planning on getting it done for foxtober fest... Hopefully it makes the dead line got all the body work done today
How did you do the five lug conversion? Assuming SN95 conversion up front with the 13” Cobra setup but not sure what you are using in the rear as the SN95 rear rotors are 10.5” in diameter for the GT/V6 and 11.65” in diameter for the Cobra.
All this helps with rim selection.
Sn95 spindles and rotors and 5 lug conversion in the rear from lmr stock length axels
Reactions: limp
Come on man, LIFT KIT AND 22s. Not really. Lift kits on cars=hilliarious.
CTS V 6 piston calipers with 15" front rotors are VERY NICE. I ASSUME they have one for a Fox, have em for WRXs. Have em on my G8. FREAKIN AWESOME. And thats in a 4000lb car.
Then again, 13s are probably enough AND DONT REQUIRE 19/20S.
Although my 8 will take a corner with its 285/30-20x4 tires.
