11 sec GT40 build....
GT40 head 61CC chamber 5 angle valve job by Rick 91GT
exploder intake ported lower by me upper is blended from inlet of the throttle body all the way as far as i can reach with a straight die grinder to remove any flash and casting marks
C&L inlet pipe with all the casting marks and flash removed
C&L meter
24lb injectors (coming soon)
Long tubes with all the welding ground smooth at the flange
B303 cam
1.72 roller rockers matched intake and exhaust
QA1 K member
stock control arms with modded bushings and double nuts
QA1 coil overs 14-175 springs
SN95 v6 electric fan
3G alt
battery in hatch
MSD 6AL2
ford racing wires (for now)
MSD cap and rotor
4.10 gears
spool
UPR radius arm uppers
UPR pro lowers
4cyl springs
focus fuel pump
lakewood 50/50's
no radio
no heat
no air ducts
no power steering
26" slicks on pro stars
thats about all of it
You'd think that but its got a lot more fuel and a lot less timing then every other hole...
Let me be of assistance;
Obviously any person who has half a brain would know that melting #4 is a direct result of too much of one thing, and not enough of something else.
Jeez! do I have to tell you everything?:rolleyes:
It seems to cool just fine. But it's been awhile since I had it out in the dead heat of summer
Looks like a job for your handy dandy cordless DeWalt 24v sawzall. My favorite tool, hands down.
Also, when's this thing gonna race again? I've been axiously awaiting and the buildup is killing me!
24V... damn i aint seen 24V stuff in YEARS! and i work for them!
i got the shift forks and top cover to the trans with me right now im going to clean them up in the parts washer to get some crap out of the top case. pretty much once the trans is back in im heading to the track
the seal on the end of the trans is the only seal back there. the tailshaft to the main case is RTV and the top cover to the main case is RTV
OK sweet I thought I read somewhere here there were two seals which didn't honestly make any sense but I'm gonna get this on order and throw my trans up in here this weekend maybe
