Clayton302
Yeah I think about the only SIMPLE way to run Meth/Water would be to set the FT tune up for the meth/water, hence the window switch for the meth/water. Just make sure meth/water is working under full throttle. I do like the idea of pulling more timing out when temps get high but this is all common practice in tuning anyways. My ICT sensor is in my manifold so it would adjust/add timing by simply adding the kit with no tuning. To get more Power out of the kit the tune could be adjusted a bit.
So are you running an aftermarket ignition box? With proper tuning someone could avoid this setup, it reminds me of the old boost retard adjustment knob for the old supercharger kitsThat's what the safety/window switch is for. Fuel and spark tables are setup for meth. So air charge temp is measure post power adder. When the safety switch if made indicating that meth is being sprayed, then timing is run full commanded/tuned advance. When not made, timing is reduced at the ignition box.
Not trying to bash anyone here, just trying to make it understood that dyno numbers aren't everything.
