Fox 87-93 LX Notchback Fox Body Front End Swap requirements?
carDaniel15
30
24
18
California
So I have been thinking about getting a Fox Body Mustang and like the rear end of the Notchback more then the hatchback but I prefer the GT Front End As I like how clean it is. What are the requirements for changing the front end? Is it a straight Bolt-On? Does It require any fabrication?
straight bolt on once you get all the parts. You'll need the front bumper and the two front fender extensions ahead of the front wheel. If you want to add the fog lights you'll need the foglamps and the support bracket and the switch.
Keep in mind, the GT and LX molding is slightly different, so from the side view you would see the difference in molding. It's subtle. The tape stripe channel is a different width between LX and GT
  • Informative
Reactions: General karthief
It is also important to note that the 87-90? is different than the 91?-93 front fenders and fender extensions (bigger wheel well opening for larger wheels/tires) so make sure you get the right fender extensions for your year model.
Look into an outlaw lx bumper cover over a gt, couple companies make them in different lengths... More for drag cars but so much cleaner then using a gt front clip..
