93 Cobra 47k miles Vortech supercharged
Brenna23
Jacksonville Fl.
I just picked up a "Garage find" 93 Cobra That has been sitting basically since 2008 or 2009 has 47K original miles, It seems to have an aftermarket shorter shifter, it seems to shift pretty good a little stiff but not bad, it goes through all the gears fine no grinding or anything, but it is very difficult to shift from 3rd back to second in that sometimes i can't get it to go into second unless i slow down to a normal speed that you would put it into second or a bit slower, and then I have to kind of slam it a little.Overall, I would say the shifter is a bit stiffer than normal. but works great except as stated above. Shifter or Trans problem? Thanks
  • Sponsors(?)
Habu135
Advanced Member
Jan 10, 2019
520
309
73
39
California
GM synchromesh. Available on Amazon at a considerable savings.
And we'd all love to see some photos.
95BlueStallion
Drop into my dm’s gurrrrrl
5,711
3,318
214
Cedar Rapids, Iowa
www.goodreads.com
Does the car have an adjustable clutch cable? Or how about a fire wall adjuster? I had installed an adjustable cable on my car once and it made my clutch very stiff and my transmission much harder to shift. Went back to stock and both issues disappeared. If there is a firewall adjuster, try making some adjustments to the preload on the clutch and see if that helps. It basically sounds like it’s out of adjustment to me.
Thread starter Similar threads Forum Replies Date
B Just picked up a "Garage Find" Red 93 Cobra Gray Leather 47k original miles. Built and owned by Johnny Lightning The Welcome Wagon 19
B 95 Cobra cooling fan 1994 - 1995 Specific Tech 0
S Replacing stock tires and wheels on my 04 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 0
Ultra90GT For Sale nitrous plate GT40 cobra Engine and Power Adder 0
J Brakes 03 cobra calipers on my 86 Fox 5.0 Mustang Tech 1
JimmyJamTheHamSlam Part Suggestions 1996 / 1998 4.6L DOHC Mashup Engine Rebuild SVT Tech Forum 0
D The definitive SN95 GT to Cobra brake upgrade. Part numbers and pictures. 1996 - 2004 SN95 Mustang -General/Talk- 3
B Engine Questions regarding a 93 Cobra Vacuum Leak/Intake Manifold Fox 5.0 Mustang Tech 6
K Cobra Front Bumper 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
J 2001 Ford Mustang Cobra SVT Convertible Fuel Smell help 1996 - 2004 SN95 Mustang -General/Talk- 2
D 1999 cobra blower questions SVT Tech Forum 0
C What's it Worth? In the market for new wheels What is it Worth?!?!? 1
K Paint and Body COBRA BUMPER 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Cammandobrando 97 cobra magnaflow street series 1996 - 2004 SN95 Mustang -General/Talk- 1
S Interchangle Exhaust 01 Cobra-93 Fox The Welcome Wagon 0
calmlikeabomb 96 Cobra power steering issue... what is this line? can I replace it? SVT Tech Forum 0
C Advice for cobra IRS swap? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
B SOLD For Sale - 1993 Mustang Cobra - Black on Black 75254 Miles Fox Body Mustangs For Sale (1979-93) 2
W Newbie looking to identify or confirm a 93 Cobra Engine? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
D 99 cobra engine fuse box wiring loom 1996 - 2004 SN95 Mustang -General/Talk- 0
B Fox Just picked up a sick set of cobra rims the rears are 17x9 and the fronts are 17x8 whats the biggest set of tires i can put on there guys 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
L 1997 Cobra Tune Question (and some background on the car) SN95 4.6L Mustang Tech 3
Cammandobrando 97 cobra cobra , rear end, how much power will it take ? 1996 - 2004 SN95 Mustang -General/Talk- 1
N add oil to rear differential in 2001 svt cobra SVT Tech Forum 0
C Expired 99-01 Cobra IRS Suspension Parts 0
C 1998 Cobra engine bogs down when accelerating 1996 - 2004 SN95 Mustang -General/Talk- 0
M 1994 Mustang COBRA - speedometer not working 1994 - 1995 Specific Tech 11
9 95 cobra 5.0 fan problems 1994 - 1995 Specific Tech 3
Habu135 Fox : How Much Power Does a Stock 1993 Cobra Make? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Cammandobrando 97 cobra s trim 10lbs of boost guess 1996 - 2004 SN95 Mustang -General/Talk- 0
Cammandobrando 97 cobra s trim 10lbs of boost horse power guess The Welcome Wagon 5
J Suspension INSTALLING COBRA IRS INTO 1965 COUPE Classic Mustang Specific Tech 1
J Progress Thread ANYONE INSTALLED A 1997 COBRA REAR END ASSEMBLY IN 65 COUPE? 1965 - 1973 Classic Mustangs -General/Talk- 3
9 Coyote swap alternator wiring 1996 - 2004 SN95 Mustang -General/Talk- 6
M Electrical 95 cobra random dyno numbers 1994 - 1995 Specific Tech 8
N Fox Lift struts / shocks for 93 Cobra 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
T 96 mustangt will a 2003 cobra guage cluster work in a 96 gt SN95 4.6L Mustang Tech 3
R 3rd gear pedal down vibration SVT Tech Forum 0
B Spotting the difference between 95 5.0 gt and 5.0 cobra 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 39
D WTB/Trade 03-04 Cobra/Terminator Side Skirts SN95 Mustangs For Sale (1994-04) 0
C Drivetrain Super 8.8 ring and pinion 2015+ Specific Tech 4
G +40-45mm offset 17x9” wheel recommendations for 93 cobra 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
9 97 Cobra Coyote swap Randomly won’t start 1996 - 2004 SN95 Mustang -General/Talk- 10
F Junk yard find Cobra 1974 - 1978 Mustang II Talk & Tech 10
csbarracuda Engine Crane Cams 1.7 factory roller rocker question F3ZE-6529-AB 1994 - 1995 Specific Tech 3
9 97 Cobra Coyote Swap Alternator Issue 1996 - 2004 SN95 Mustang -General/Talk- 2
C For Sale Moser 8.8 Rearend Drivetrain Parts 0
C For Sale Moser 8.8 Complete Rear End Drivetrain Parts 0
boostfrk WTB/Trade ISO JLT Fenderwell Intake for 96-98 Cobra Engine and Power Adder Parts 0
J Cobra wheels The Welcome Wagon 1
