Anybody using lift struts instead of prop rod?
I know in my Redline kit it had two different install locations depending on what kind of hood you had, maybe you used the wrong measurements?
Nope, used the measurements for the 79-93 hood. I'm convinced that the lower mount points on the driver side was probably 1/8th" or more off. probably enough to compress the shock too hard, and it wouldn't compress anymore and the result was a bind. Bottom line...my fault.
Thought about them, but after replacing the hatch struts on my GC and Explorer, and the hood struts on the Explorer today, I am not putting them on anything that does not have to have them.
Prop rods are cheaper and do not need replacement.
