I am going to be having my transmission fluid and filter changed out shortly, and I figured I may as well have them install a shift kit while they have the pan off. With all the choices of shift kits (Bauman, Trans-Go, Performance Automatic, Jerry mod from tccoa) I don't know which one to choose, or which setting I should have it installed on. I do however, know from my limited amount of research to stay away from B&M kits.
I know that when I get a PI or Edge 9.5" aftermarket converter, that it will soften up the shifts quite a bit, so I want to compensate for that as well.
With all of that said, what shift kit do you guys have in your AODE stangs, and what setting do you have it on? Which setting would you recommend I have mine set at when I have one installed? Are you happy with the quality of the kit?
Thanks in advance!
-Jason
Thanks in advance!
-Jason
So I told them to go **** off, and left. I called around, found a shop and made sure on the phone they knew exactly what i was talking about. They did excellent work, and had it done within a reasonable amount of time.
but then again it won't even chirp 1
