That 308 degrees spec was at .005 lift, not the more often used .050 lift now. And even though it was a somewhat long duration, the lift at the valve was only .500 . For a really impressive sound, nothing beats three dueces , with quiet mufflers, preferably romped on in a downtown street between the buildings A 63-1/2 Galaxie 427 will be a low-riser, unless it came from a factory drag car. As for exhaust, the more cubes you have pumping thru it, the louder it gets. A muffler and pipes that are somewhat quiet for a small block will be noticeably louder behind a big block.
You are right, the 308 duration is NOT @.050 lift, but is still very lopey. The entire motor has been rebuilt so I am completely assuming that is has more lift than .500. When I get the specs this weekend I will post them. I do like the high compression, tinny header and muffler sound that Flowmaster has, and it will still sound incredible with that system, but I was looking for something different. If not flowmaster it will be going on. The system will be atleast 3 inch all the way back.
After dealing with full length Hookers on my 67 with both the 390 and 427,
