Cam selection guidance.
02 281 GT
Agreed...My wife has great Boobs
3,208
1,973
194
Cabot, AR
Hi. I'm new to these forums, and I have a '95 Cobra that I picked up last month. Current mods are in my sig. I'm looking to just keep it lightly modified for now (it's pretty much where I want it with the exception of suspension mods and paint). Can y'all suggest any cams that I could use with my stock motor without having to tear it apart (IE: notch pistons for clearance).
Thanks in advance.
Yep. Either save the money or put it into something else(shot of nitrous maybe).
I'd try to save up and get a used set of aluminum heads if i were you. Or maybe look at the gt40 threads to see what guys have.
I like to remind guys to figure out their end goal for their car before they start getting parts here and there. If in 2 years you want a turbo car, or a n/a monster, then start laying the foundation for that now. You may sacrifice a little more now, but you'll save money and time if you know the direction you are going.
Will a cam give you more hp :shrug:
Yes for sure ... but ... Is it worth it if you look at the big picture :scratch:
I'm no cam Guru but I do feel I got a basic understanding about how all
the various parts work together ... good or bad :)
You got a basic GT40 combo at this time and they usually run in the
range of 245 to 275 rwhp dynojet sae calibration
The whole GT40 combo thing was designed around OEM Iron heads
that have VERY POOR exhaust efficiency
Those combos also were setup for a bit of extended rpm range
but
You gotta stay within reality here :Word:
I mean ... heavy roller lifters and wimpy OEM v springs won't do much :nono:
So ... having laid all that down you should see how limitations are in place :(
Talking big 3 (h/c/i) If you move away from OEM and go to aftermarket ...
Unless you go aftermarket with ALL 3 you kinda shoot yourself in the foot
as far as getting the BEST performance
I'd say those shortys are holding you back big time in your low/mid rpm
range
For a NA street combo ... LT's make such a difference in that area :nice:
For what you now got .................
I'd think a custom cam and sharp tune would give you .......
The most go for the least dough :)
The cam guy will take what you now got and be able to tell you what is
possible AND he can also tell you what might be possible if you go to
different combo parts
My reasoning is the cam and tune will give you good gains and still stay
within the narrow range of rpm you got to work with
NOW ... you gotta ask yourself :scratch:
What gains if I went with the big 3 aftermarket combo parts and stayed NA
290 to 310 rwhp dynojet sae calibration
To get the best performance you gotta have all the supporting parts which
you certainly don't have at this time :(
So ... You got a lot of cash laid out for not all that much more hp :bang: :fuss:
Maybe some juice or a blower might be considered :shrug:
Here are some NA combos based around OEM IRON heads
and Aftermarket Aluminum heads
Hope this gives you some stuff to think about :D
Grady
