do i need to up grade?? maf & injectors
rod196202
44
got new y303 turbo swirl heads gt40 intake tubeular dieing to install but need a few more things first as i need to have a cam ground and find a little time but when i in stall i want to do it right and get the most out of my parts befor i ramble on ill get to my question do i need bigger t/b for the gt intake i now have 65mm do i need bigger injectors & maf mine are stock now i was looking at c&l 73mm maf with 42lbs injectos sold as kit 399.00 is that to muc$$$ is this all i need to change or what i want to get every thing befor i get custom grind on a cam any ideas... Thanks
rod196202 said:
ok 24# 80 mm t/b pro m what fule pump should i go with do i need to change fule rails as well... thanks for your input it does help...
80 mm pro-m .... not an 80mm tb!!!!
The 65mm tb you have will work fine, you could probably use a 70, but the 65 will work. Get a 255 walbro pump, you could get by with a 150something, but if you get a 255 now (like $20 more) you will never need a bigger one.
(imho of course)
DD
:flag:
