Extremely Low Mpg...why???
  • Thread starter Thread starter rideapony
  • Start date Start date May 21, 2017
  • 3
  • 4
  • 5
First Prev 5 of 5
rideapony
168
20
39
SANTA ROSA, CA (North Bay Area)
Jun 3, 2017
#81
  • Jun 3, 2017
  • #81
Now, I have removed all the smog system long time ago, removed the rear crossover pipe from the heads and plugged the holes on the heads with a couple of setscrews, do hot air still coming out from the center of the head to the intakes? If so how to plug those holes? My lower intake gaskets have no holes.
Please advice. Thank you all!!!
rideapony
168
20
39
Jun 4, 2017
#82
  • Jun 4, 2017
  • #82
Well I found answer to my inquire. Fel-Pro has an article that says, "No need to modify the 1250S3 gaskets to install the plugs, the gaskets will do the job and survive the crossover function"
I found out some interesting thing that obviously I'm guilty of. With the new set of 1250S3 gaskets I put them over the intake mating surface and to my surprise and embarrassment I installed the old one WRONG!!!
The old set looks like they shifted under torque but they didn't. I installed them up side down. I put some weatherstrip glue any ways just to prevent possible sliding. at back and rear I put a Ultra black silicon strip, I just snug the nuts and will let it set about 12 hrs before doing final torque to specs.
I really don't think there was a vac leak but itf it was it should be corrected . Will see what it does after everything is together and fired up.
Usually I take problematic matters very seriously, and this is not the exception. I learn and fix the problems.
Thank you all
Admin Dude
Jan 4, 1985
43,564
21,734
234
Box behind Walmart
Jun 4, 2017
#83
  • Jun 4, 2017
  • #83
Let us know how it turns out drives. It should be a different animal.
General karthief
Mod Dude
Aug 25, 2016
28,133
10,749
213
polk county florida
Jun 4, 2017
#84
  • Jun 4, 2017
  • #84
Thank you all
Why wait 12 hrs before torquing the manifold?
Admin Dude
Jan 4, 1985
43,564
21,734
234
Box behind Walmart
Jun 4, 2017
#85
  • Jun 4, 2017
  • #85
Read above
rideapony
168
20
39
Jun 4, 2017
#86
  • Jun 4, 2017
  • #86
you're right Noobz347, it better be a different animal or else!
I've been reading articles left and right, I follow the things that make sense and ignore the ones that don't.
I will allow the Ultra Black RTV to set before doing the final torque. Right now the silicon is already sandwiched and only applied about three pounds of torque evenly. If I do final torque before the silicon sets I will squeeze it out of the mating surfaces.
Will see how it works out
rideapony
168
20
39
Jun 5, 2017
#87
  • Jun 5, 2017
  • #87
Udate:
Up and running and it seem to be doing the same, vacuum is 9 in and have a hunting idle.
So I adjusted timing to 12* and speed up the idle to 850 - 900 rpm. I see about 12 in of vacuum.
I did this with the IAC unplugged and at normal temperature, TPS is at 0.985 Volts.
Disconnected the negative terminal at the battery to reset the computer and still doing the same hanging .
One weird thing I noticed is that even with the IAC disconnected and while doing the throttle stop adjustments and I stab the throttle the revs go up and stay there for a few seconds and then drops to the set idle speed, why is it doing that? is this considered "Hanging"??? Why is hanging without the IAC? Could I have a bad PCM???
I also tried to set the base idle using the 0.010" filler gauge but once I reset the computer and connect the IAC it just idles way too low, and hangs up high while shifting dropping to idle until get to full stop.
please I want to hear your opinion about this.
Thank you all!!!.
General karthief
Mod Dude
Aug 25, 2016
28,133
10,749
213
polk county florida
Jun 5, 2017
#88
  • Jun 5, 2017
  • #88
What computer do you have in the car
rideapony
168
20
39
Jun 5, 2017
#89
  • Jun 5, 2017
  • #89
I have A9L
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jun 6, 2017
#90
  • Jun 6, 2017
  • #90
Why are you blocking the center ports to the intake that feed the EGR? The EGR does contribute to cruising fuel economy somewhat, so blocking this ports in essence eliminates the EGR and will results in a slight worsening of fuel economy.
Since that seems to the be the main intent of this thread, it makes no sense to do this.
rideapony
168
20
39
Jun 6, 2017
#91
  • Jun 6, 2017
  • #91
Well following chronology steps, there was a massive vacuum leak at the EGR valve. Thinking that that was the problem of my low vacuum which also contributes to low fuel economy, I removed the EGR valve and replaced the spacer with a thinner plate. Since my low vacuum problems persisted I went and removed the lower intake and as I was ready to re-assembly I found out that the Fel Pro 1250S3 gaskets don't have a cutout for the EGR passage from the head, and since the valve was not there already left it blocked. And the results as updated, were that low vacuum numbers still the same.
That's the latest situation, I must say that I still think there is a vacuum leak but, where???
Today I intend to run a compression test on a cold engine and see what numbers I get. Would that give a possible internal vacuum leak indication?
At this point I rule out a leak under the low intake because I followed every suggestion at installation meticulously.
Even though it is quite of work I really don't mind to remove the LIM again if I have to re install the EGR but I would like to focus on this potentiallly mysterious vacuum leak.
Please comments and or suggest.
Thank you all!
rideapony
168
20
39
Jun 6, 2017
#92
  • Jun 6, 2017
  • #92
I just ran a compression test. I warmed up the engine for about 15 minutes, removed all the plugs, and unplugged the coil and fuel pump relay, and then proceeded with the test. The results are NOT good
Compression test results:
# 1.- 120 Dry
# 1.- 148 Wet
# 2.- 135
# 3.- 135
# 4.- 130
# 5.- 110 Dry
# 5.- 140 Wet
# 6.- 138
# 7.- 135
# 8.- 135
Cylinder # 1 is borderline good but # 5 is definitely out of specs. What do you guys think?
A few days ago I ran a cylinder balance test and it was good.
So where should I go from here???
Please advise or suggest. Thank you
rideapony
168
20
39
Jun 7, 2017
#93
  • Jun 7, 2017
  • #93
Sorry I ran out of the initial topic, unfortunately here is where the whole thing took me. Now with this new issue I might have to put new rings and do all the bearings to freshen it up.
Thank you all
  • 3
  • 4
  • 5
First Prev 5 of 5
O2 Sensors Acting Weird
  • PonyGTrider
  • Nov 6, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 9, 2023
PonyGTrider
Fuel 19lbs EV6 fuel injectors, what fuel pressure???
  • PonyGTrider
  • Jul 11, 2024
  • 6 7 8
13K
Fox 5.0 Mustang Tech Jul 25, 2024
PonyGTrider
K
95 GT Issues and Codes - 158, 172, 176, 212
  • kfvintx
  • Sep 1, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2023
manicmechanic007
LESS THAN 9.5 MPG CITY DRIVING!!!
  • PonyGTrider
  • Dec 15, 2022
  • 3 4 5
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2023
PonyGTrider
Engine 1988 LX 5.0 shaking violently and popping under acceleration - video inside
  • lepryy
  • Sep 19, 2019
11K
Fox 5.0 Mustang Tech Oct 8, 2019
lepryy
