Going to the track this weekend!!!
  • Thread starter Thread starter GTJake
  • Start date Start date Jun 17, 2005
  • 3
First Prev 2 of 3 Next Last
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jun 20, 2005
#21
  • Jun 20, 2005
  • #21
Ouuucccccchhhhhh... my engine is coming out today too.
GTJake
3,049
Ann Arbor, MI
Jun 20, 2005
#22
  • Jun 20, 2005
  • #22
Got it torn down to the heads in a couple hours. But I have to go to work now. I should get a ps puller and balancer puller tomorrow and get the heads off.
Hopefully the shortblock isn't trashed.
Jake
Joes95GT
3,132
Delaware
Jun 20, 2005
#23
  • Jun 20, 2005
  • #23
Damn, that really sucks! I don't know what to say... Hopefully it's just a bunch of valves and bent pushrods (not engine damage).
...keep us posted....
Joe
GTJake
3,049
Ann Arbor, MI
Jun 21, 2005
#24
  • Jun 21, 2005
  • #24
Popped the heads off this morning. Looks like a popped all the exhaust valves into the pistons. So...
What exhaust valves?
I can prolly do the work myself?
Should I replace the springs?
I'm glad I didn't retard the cam like I was thinking this spring. The exhaust valves would have had even less clearance and prolly caused some major damage.
Thanks
Jake
89 blue lx
1,936
FSU in tallahassee GO SEMINOLES!
Jun 21, 2005
#25
  • Jun 21, 2005
  • #25
so no piston damage. short block is ok?
GTJake
3,049
Ann Arbor, MI
Jun 21, 2005
#26
  • Jun 21, 2005
  • #26
Well there are knicks in the piston, but it should be fine. Custom 7500 rpm valve reliefs...
Jake
cavscout371
277
#27
  • Jun 21, 2005
  • #27
Jake
Guess thats one way to flycut pistons
What kind of setup did/do you have?
GTJake
3,049
Ann Arbor, MI
Jun 21, 2005
#28
  • Jun 21, 2005
  • #28
The bandwagon AFR/FTI/Edelbrock setup.
Jake
WhiteDevil
2,717
San Diego
Jun 21, 2005
#29
  • Jun 21, 2005
  • #29
Damn i would have guessed it to be the intake valve. Well i guess its better that way. See if you can get some pics up later it would be interesting to know what they look like. Good Luck Bro
Y
yellow1995Cobra
2,959
Massachusetts
Jun 21, 2005
#30
  • Jun 21, 2005
  • #30
i had ed c fix my afr 225 heads after my accident. All my valves were toasted though. It needed bowl work as well. It did cost a few bucks, but its not something i would wanna do myself.
Joes95GT
3,132
Delaware
Jun 21, 2005
#31
  • Jun 21, 2005
  • #31
There are lots of good valves out there, but I wouldn't worry about that right now.
Are you sure you didn't bust up the valve seats in the process? If the seats are torn up, putting new valves in isn't going to help.
If the seats are OK, changing springs with the heads off is cake. Get a valve spring compressor (you can find them at most auto parts stores), and go to town. Once you see one, it'll be very self explanitory on how to change the springs. Ed will have the (good) springs, and (good) valves for you.
Joe
Killercanary
The car that set the bar.
Altoona, PA
Jun 21, 2005
#32
  • Jun 21, 2005
  • #32
That's EXACTLY what I did Jake. I suggest calling Ed on the valves/springs. I am still up in the air as to what I'm going to do with mine. I might just buy a new set of heads (stud mount this time) and repair my damaged ones over time and put them on my '90GT.
EDIT: I missed page two, so I agree with the others on checking the valve seat and getting with Ed for the replacement parts.
Do they look like mine?
GTJake
3,049
Ann Arbor, MI
Jun 21, 2005
#33
  • Jun 21, 2005
  • #33
Yeah, they look pretty much like that Paul. Not as bad though. Yours look like 180* of the valve hit the piston. Mine is more like 90*.
I would imagine the seats need some work. Would that change the exhaust port cc's?
I think I may get the parts from Ed, but have them installed locally.
I'm pulling the timing cover to redo my timing cover gasket, so I'll check the timing chain. Should I just look for exess slack? It's a new Rollmaster (last summer).
I'm almost thinking while I'm in here to get a wilder grind from Ed. I'm not sure how much it would be worth. I thought he had a cam exchange deal where you send him your old one and he sends you a new one for a discounted price. Opinions?
Am I correct to assume the dents put in the pistons will be fine? I should have extra clearance next time right
Joe or JP- Do you know if it's the 'rev_limit_0_off' or 'rev_limit_0_on' that is the real rev limiter in the tweecer? Cuz I definitely don't think 6250 could have done this. More likely the 7500 limiter in the J4J1 cal(rev_limit_0_off).
Jake
WhiteDevil
2,717
San Diego
Jun 21, 2005
#34
  • Jun 21, 2005
  • #34
Like i said when we talked in the im earlier the 6,250 is the limiter that you hit, buuuutttt it would do nothing to stop the over revving of dropping it into 2nd at that high of a MPH even with the limiter going it will rev past it without problem because its a mechanical thing.
GTJake
3,049
Ann Arbor, MI
Jun 21, 2005
#35
  • Jun 21, 2005
  • #35
Think I should change the limiter anyways?
Jake
WhiteDevil
2,717
San Diego
Jun 21, 2005
#36
  • Jun 21, 2005
  • #36
Jake
Higher or lower?
Killercanary
Altoona, PA
Jun 21, 2005
#37
  • Jun 21, 2005
  • #37
The T4MO rev limiter is 7000rpms Jake, not 6250 like the A9L stuff. I have lowered mine to 6400.
WhiteDevil
2,717
San Diego
Jun 21, 2005
#38
  • Jun 21, 2005
  • #38
Yeah but he is running a cobra J4J1 which has a 6250 limiter
GTJake
3,049
Ann Arbor, MI
Jun 21, 2005
#39
  • Jun 21, 2005
  • #39
The J4J1 has a 6250 and a 7500 limiter. I was thinking about putting both at 6400.
Jake
Joes95GT
3,132
Delaware
Jun 22, 2005
#40
  • Jun 22, 2005
  • #40
I've got mine set at 6500 or 6600. I can't remember.
I was shifting mine on the street at ~6300 and I tickled the limiter a few times on the 1-2 shift.
I don't know about yours, but I know my timing chain was a mother F'er to get on. If it's got any slack in it, get rid of it. High performance chains aren't like stock chains where they stretch and stretch forever. High performance chains will stretch a little before they break. That would be ugly.
Keep the cam you've got. That's got more than enough power to get you into the 11's. If you want to spend money - flycut the pistons a little bit and retard the cam. I'd like to see it run that way.
Hope everything goes good....
Joe
  • 3
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 9:11 AM
smittys7up
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
