Have I got two faults
Reckless_b
40
62
South Yorkshire U.K.
Hi all, we’ll yesterday I decided to do what I should have done at the start and remove the ccrm to test on the bench. This reveals an issue, the circuit that powers on the pcm has a problem, the pilot through the relay showed open circuit. So I thought in for a penny etc and drilled out the rivets, opened it up and had a look, tested again and no circuit across the pilot. I carefully removed the relay and fitted a replacement, tested and was ok, I boxed up the ccrm and refitted to the car. Refitted the inner arch shield and put the wheel on, I’ve removed to temp fly lead and all the wiring is back as it should be, now the fuel pump primes, power is through to fuses f2.2 and f2.8 when key on.
The theft light acts normal put still no start, it’s as though the pcm isn’t speaking to anything even the OBD2 scanner gets no clear messages. What do I need to do to get the pcm to join in,
I haven’t tried the spare key yet, I’ll do that soon, just in case.
Bill
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,807
499
164
Houston Texas
I believe I gave you the "crank with no start" check list in your other thread. But here it is again for your reference. Once a repair has been made you have to start the trouble shooting process over from the beginning as if this is a NEW problem. Don't ASSUME anything.
From the "crank with no start check list" pay attention to what the check engine is supposed to do during cranking. Pay attention to HOW PATS is supposed to "prove out".
1996+ Crank with no start check list
This also applies to the power on test for fuse F2.34, F2.2, and F2,8. Then you won't be guessing IF you have a PATS problem or not.
Reckless_b
40
62
Crank with no start check list complete, checks out ok, it seems now my fuel pump is not supplying anything, when I first put power through to the ccrm via a fly lead I’m certain the fuel pump ran, the engine started etc, now the fuel pump doesn’t run, I can hear the ccrm relays buzz for a few seconds and then time out, I’ve listened in the trunk an it’s all quiet in there.
On a plus side, a squirt of easy start into the throttle body has the engine fire, one step forward, two steps back.
I’ve checked all the bjb fuses and all are good, I suppose next I’ll be testing at the fuel tank area.
Bill
wmburns
Aug 14, 2009
5,807
499
164
Houston Texas
I have helped several people reporting a "buzz" from the CCRM. In almost all cases the cause was traced to a bad CCRM or PCM ground.
Reckless_b
40
62
Oops, I’ve found the fuel pump fault, I’d left a plug disconnected in the passenger foot well when I’d been checking the pcm, plugged back in fuel pump ok, battery hasn’t enough power to try to start engine new one ordered.
Reckless_b
40
62
Hello again, could you help by advising on spark plugs for the 3.8 as motocraft plugs are virtually unobtainable, champion ,ac delco and Bosch are available, currently NGK bpr5efs are fitted but I’m not happy with them.
Bill
Reckless_b
40
62
She lives!!!
With everything put back as it should be, the ccrm with a new relay fitted for the pcm supply, and the fly lead removed, also a new battery fitted but I finally tipped the old one over the edge with excessive starting attempts so not really part of the problem, the engine fired up first time.
I’d like to express my thanks to Mr wmburns
Without who’s help I’d still be poking about looking for the fault, thank you sir,
Bill
Thread starter Similar threads Forum Replies Date
Sleepy McNastee Vent..got in a wreck...not really my fault, but... 1994 - 1995 Specific Tech 24
Andresquintana.mma Fox Just got a 93! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
N Bought a unfinished 5.4 dohc into 97 gt project. I)ve got lots of questions. The Welcome Wagon 2
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
M Progress Thread .351 roller, cam bearing cracks, I've got em #2 & #4 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
C Just got a 1990 lx notchback. I need help please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
DudeStang Progress Thread Finally got my first Fox Body - 1988 GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 325
Twitch'n Twitcht4life My P.M.S. got stolen from my car. Hey 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
mattbaker302 Gots me a 351 Cleveland 1965 - 1973 Classic Mustangs -General/Talk- 12
J Electrical finally got my head lights SN95 4.6L Mustang Tech 0
joetrainer31 Progress Thread Got Another One! Pics Fox 5.0 Mustang Tech 90
79 Fox Fox Got a problem... What is going on? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
79 Fox Fox Finally got my Fox running! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
S Engine Got a 93 mustang gt overheat on idle Fox 5.0 Mustang Tech 2
1970machwon Engine A couple MAF questions (Finally got my donor engine!) Fox 5.0 Mustang Tech 6
RangerJoe Fox New PB, finally got into the 10's! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
C Finally got this horse to pass NJ inspection !!! SN95 4.6L Mustang Tech 3
J Cheap fix for front bumper that broke off when I got the car stuck in a ditch. 2015+ (S550) Mustang -General/Talk 4
R 04 GT. JUST GOT IT. The Welcome Wagon 1
C Engine 88 got oil question Fox 5.0 Mustang Tech 11
CarMichael Angelo Well, I just got poked in the heart... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
R Please Help has anyone got image of wires The Welcome Wagon 0
John Dirks Jr What you got? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
W Hi All, Just got a 2002 mustang. It has 16 inch wheels and tires on it. Thinking about buying 18x9 front and 18x10 rear, any advice? 1996 - 2004 SN95 Mustang -General/Talk- 2
8 Just got my 2nd fox!! The Welcome Wagon 3
tessatrolo Got a wiring problem SN guys please help! 1996 - 2004 SN95 Mustang -General/Talk- 0
TNAVY Finally got a Cobra (my dream car!) The Welcome Wagon 1
C Hello from Texas. I am an old Street Rod builder who got serious about Mustangs years ago. The Welcome Wagon 5
R Finally Got to Mustang Week 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
mpeach1976 I got popped by police for my exhaust 2005 - 2014 S-197 Mustang -General/Talk- 2
J Engine 1994 GT not sure what I got here ... SN95 4.6L Mustang Tech 1
H 1986 got some turbo questions. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
S After 20 years, I got my Mustang. The Welcome Wagon 1
S Just got 18 GT. Ambient Light/ Primary/ Secondary color settings do not save when turned off. 2015+ (S550) Mustang -General/Talk 5
Steel1 Got myself a Fathers Day present 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Z Just got stanged 2005 - 2014 S-197 Mustang -General/Talk- 1
65-Fstbk Rebuilt the 5.0 but it's got an oil leak 1965 - 1973 Classic Mustangs -General/Talk- 6
G Paint and Body Spring is finally here and got the car cleaned up. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Justin Fetalvero Just Got A Free 1994 Mustang V6! The Welcome Wagon 3
Mustang Yawie Wow, It’s Been A While But Finally Got A Mustang Back 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
E Just Got A 74 Mach1 1974 - 1978 Mustang II Talk & Tech 11
FastDriver Finally Got To Drive A '16 Gt 2015+ (S550) Mustang -General/Talk 14
Chythar Interior and Upholstery Got Myself An Early Xmas Gift 1994 - 1995 Specific Tech 7
B I Think I Got Ripped Off Need Help! 1996 - 2004 SN95 Mustang -General/Talk- 4
IIGood Think I'm About To Go Broke...got A Polisher Mustang Sound & Shine All 0
Street Renegade Finally Got Headers And A Tune 2015+ (S550) Mustang -General/Talk 2
Davedacarpainter Who's Got The Best Eclipse View? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
mikestang63 Got The Latest Mm&ff Fox 5.0 Mustang Tech 3
9 How Warped Is This Cylinder Head? (just Got "resurfaced") 1996 - 2004 SN95 Mustang -General/Talk- 3
James V Fox Got A New Alternator. Quick Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
