How High Can I Rev My Setup
  • Thread starter Thread starter 302mustanglx
  • Start date Start date May 17, 2012
302mustanglx
41
mesquite nv
May 17, 2012
  • May 17, 2012
Ok fellas i wondering how high i can rev my setup.
My setup consists of
procomp dual plane intake (1500-6500)
holley 600 carb
e303 cam
longtubes (fullexhaust)
alumenum pullies
373 gears
alumenu d-shaft
gt40p heads (afr springs)
1.7 rockers
msd 6al2
msd wires
and about 30 Degres of timing
Admin Dude
Jan 4, 1985
43,538
21,705
234
Box behind Walmart
May 17, 2012
  • May 17, 2012
On an N/A car... 5800-6000 rpm before the cam stops making power.
302mustanglx
41
mesquite nv
May 17, 2012
  • May 17, 2012
what about a mild car like mine with the setup i have do u think 6000k is oky
Admin Dude
Jan 4, 1985
43,538
21,705
234
Box behind Walmart
May 17, 2012
  • May 17, 2012
I think it's fine so long as you don't bounce off the rev limiter.
Deisregard that statement... you don't have a rev limiter. LOL
whitey68
56
12
central illinois
May 20, 2012
  • May 20, 2012
stick it to the wood, watch the tac, make a note of when it kicks out a rod......... you want to be just under that rpm. lol
T
tobalx
53
  • May 21, 2012
i have a simalar set up,gt40 e303 1.72 rr's and mine hits the "wall'' at 6100. no point going past it. i shift at about 5900
Admin Dude
Jan 4, 1985
43,538
21,705
234
Box behind Walmart
May 29, 2012
  • May 29, 2012
Moved to tech
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
May 30, 2012
  • May 30, 2012
Stock lower end? I wouldn't take it much past where the stock rev limiter would kick in
Sent from my iPhone 4S using Tapatalk
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
May 30, 2012
  • May 30, 2012
With an e cam, you are going to run out of the power long before you damage the engine.
Operating range of an E is only up to 5500rpm.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
May 30, 2012
#10
  • May 30, 2012
  • #10
yea he does... the 6AL2 has an adjustable one in it
Reactions: 88LX5.Oh
Rick 91GT
Mustang Master
95
99
PA
May 31, 2012
#11
  • May 31, 2012
  • #11
Yeah Im with 2000xp, that car will be out of breath by 5400rpm....
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
The Most Preferred Aluminum heads
  • SSnakeGT127
  • Mar 9, 2021
  • 2 3
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 28, 2021
SSnakeGT127
Fox Can I Run A Dr With My Stock T5?
  • PakstinN
  • Aug 13, 2017
  • 3 4 5
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 20, 2017
PakstinN
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
