How much NOS?
rclifton
38
North Carolina
I wanna put a small shot of gas on my car but not sure how much! First: How much compression should a stock 89 Mustang have with 58cc afr 165's??
Second: how much NOS should I spray 100 or 125?
So here's my setup: 306, afr 165's, Performer RPM heads, 24 lbs, 70mm throtle body, 75 mm mass air,Crane HI-6 igniction, (Lunati cam) lift =550 intake,565 exaust, duration not sure 220 or 230 @ .50, stock fuel pump.
You will run that thing lean if you try to spray it with the stock fuel pump in there.
Get the fuel system up to snuff and you can spray the hell out of it. Nitrous likes compression. You're no higher than 9.7-9.8 ish CR with the 58cc heads.
ASSuming you get it enough fuel and aren't detonating, you're really not in the danger zone with a stock pre-'93 5.0 bottom end until you're at a 200hp shot or higher, at least from what I've seen.
throw a 255 intank in it and hit it with a 100 to start with and get use to it... then go up from there.
id try the timing around 8* with 93oct and a 100 shot. might be able to get away with around 9-10 buts id do 8 to start and be safe.
