I can tune anything remotely.. I do it every week. Most adjustable is not correct, in fact the terminator X is almost simplistic with quite a bit locked away from the average user. It does not even have a reasonable way to deal with idle issues unless you know how to generate your own iac follower tables.
I can and have tuned 1000hp builds on a basic $300 micro squirt ( for all purposes is basically an ms2). You can build a harness for cheap if that's your thing, I personally just go steal a harness off a newer LS engine and use it on my sbf.. makes coil packs and cam crank sensors easy to get done. Pin some ampseal connectors and use an microsquirt, ms3pro, or goldbox(ms3 based).
Way more capable ecu than the terminator and done cheaply with a bit of work. But not for everyone as it does require more than average effort.
agreed.. The Holley terminator is a nice piece but is not the "self tuning" or " most adjustable" system on the market. I see on Bookface groups all the time posts that go like this..
I want to get rid of my 30 year old wiring and EEC what should I buy
Is told by the people who already bought the Holley to buy it
He then buys it and the questions start
How do I keep my A/C?
How do I keep my Airbag?
How do I keep my stock gauges?
Why is my idle and IAC crappy?
Then they find out they have to REUSE part of that 30 year old wiring for the A/C and Airbag.. doh
Then they get the harness and see the recent QC issues with mislabled,mismatched, broken wires, connectors, etc.
Then the next post from the guy is usually... asking for help to get it dialed in or i am going to have this tuned....
lol
IMO if you want a true plug and play get the PRO M or Haltech system. The issue is there is less support and tuners for them vs. Holley.
Personally, the stock EEC and harnesses if in good shape can well support most builds.
Not sure why people bash the Mega and Microsquirt so much. They do have a higher learning curve for most people, but if you are going to pay for a tune anyway.....
Steve is a wizard and can probably tune a car as good as anyone I know.
just my 2 cents of ignorance.
