Personally, I think it's badass and wouldn't do much to try and solve it so long as tuning numbers looked good.
I know nothing about boosted applications but I figure there is a tps on the throttle body, mine had a bad spot between 1300 and 1800 rpms, when I checked it with a vom it would bounce to zero in that rpm area causing my low speed bucking.
just throw'n that out there.
Duh me. Good point. I will just check it out to rule it out.You don't need to have it running to check it, koeo, with the vom hooked to the tps open the throttle slowly and the numbers should rise and not jump back to zero.
Haha well... trust me you would be less jealous if you had all of the problems i faced... I thinkkkk I see light at end of the tunnel now though..I'm a little jealous, only I want a blower sticking out of the hood all shaking, wheezing and scary
That would be awesome if you can. I can keep tunes separate so we can see whats being worked on and whatnot. It is possible I have another underlying mechanical issue but I think I have addressed them all. I hope it is down to the tune at this point.Do you want me to fix the idle for you? It will only take me a few key strokes.... I dont want to step on Seans toes though so i have not offered.
10-4 let me work some magic when I get home and we will see if it helps.That would be awesome if you can. I can keep tunes separate so we can see whats being worked on and whatnot. It is possible I have another underlying mechanical issue but I think I have addressed them all. I hope it is down to the tune at this point.
FYI Sean is a very cool guy - I am glad I got to meet him. I recall he called you when he was with me other day. Sorry I would call you if I had the ears haha, I am a deaf guy and American Sign Language is my main language and english is 2nd. Therefore I am limited to texting/messaging with you In other words, you wont be stepping on anyone's toes, especially Sean's.
