Administrative Just a Heads Up
  • Sponsors(?)
stanglx2002
CT Material here
Mod Dude
Jul 7, 2005
1,403
962
154
I know that its only Thursday... I think its Thursday... oh wait it is Thursday
Well still cheers anyways :cheers: I just blame Noobz
Reactions: 2Blue2
revhead347
My mission is to out curmudgeon you
8,170
1,080
214
40
Acworth, GA
Unfortunately, due to the Rona, I have lost 3 years of my career life.....again. So I work weekends now, and Thursday is my weekend. Key tip here, if you are enthusiastic about stretching out a car project for a quarter of a Century, go do the airplane pilot thing.
Kurt
Reactions: 2Blue2
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
13,859
234
62
Birmingham, al
m.imdb.com
Kurt
Wait, you're an airplane pilot..
And here I thought you were on a full time mission to tell me how fcked up the stuff I do is gonna be..:shrug:
revhead347
8,170
1,080
214
40
Acworth, GA
Yeah man, I thought everyone knew that. I've been trying my hand at this flying airplanes thing for 22 years now. I fly airplanes for this company called Delta now, you probably never heard of it. What other possible reason could there be to endure the sespool that is Atlanta? That's my side gig, my full time mission is to out curmudgeon you.
Kurt
Reactions: 2Blue2
CarMichael Angelo
13,859
234
62
Birmingham, al
m.imdb.com
Kurt
you can’t.
and it’s “ Cesspool “
CarMichael Angelo
13,859
234
62
Birmingham, al
m.imdb.com
you can’t.
And now that I know that, I think it should be mandatory that every single comment you make begins with.
Good morning/afternoon/evening folks, On behalf of those of us here at Delta, I’d like to welcome you onboard flight ###### non-stop travel from Atlanta to XXXXXX. I’m Capt Curmudgeon and i’ll be haulin your workout clothes/ pajama wearin asses from here to there today. Our flight time is ##### which should put us at the gate at XXXXX at XYZ PM. So, sit back, relax, and shut the fck up.
7991LXnSHO
Now I want a 10 year badge
Sep 1, 2010
2,549
415
124
Kearney, NE
RevHeadKurt,
Does this mean they are not doing temporary layoffs, but permanent cuts? Or are the airlines just shutting down? That really sucks if it is what is going on. Financial gurus instruct us to have 3-6 months emergency funds available, but this is taking longer than 6 months. And when it’s under control, people are going to be traveling again and your skills will be needed. So how are you at crop dusting?
The local Hyvee has a pick your pack from craft brew varieties.
I’d send a 6 pack and a sympathy card if I thought 90-100+ degree weather and the delivery drivers would not ruin it on the way.
Kurt
Thread starter Similar threads Forum Replies Date
Andresquintana.mma Fox Anyone know what heads these are 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
D 94-95 with gt40 heads valve clearance 1994 - 1995 Specific Tech 5
N Head gasket size after boring block? 1996 - 2004 SN95 Mustang -General/Talk- 1
S 95 gt mustang 5.0 cylinder head, rare set of heads/casting no. The Welcome Wagon 3
Scott7512 Engine Cylinder head options Fox 5.0 Mustang Tech 3
D Engine 8548 PT2 Head Gasket orientation (reversible?) - SOLVED Fox 5.0 Mustang Tech 1
R Engine Ford Explorer GT40 intake and heads Fox 5.0 Mustang Tech 11
H Engine 87 5.0 head gasket Fox 5.0 Mustang Tech 3
darkfader Engine Head Gasket Choices Help Fox 5.0 Mustang Tech 17
T Blown Head Gasket(I hope) SN95 V6 Mustang Tech 4
Scott7512 SVE Heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
93notchback347! What spark plugs do I use with canfield heads and vortech v1 blower Fox 5.0 Mustang Tech 3
555shotgun For Sale WTB 2002 2 valve heads Engine and Power Adder Parts 0
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
T Gt40 head swap with windsor heads???? The Welcome Wagon 2
Madness7645 Need advice - small cracks on block from water jacket to head bolt hole 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
D Headers with Trick Flow heads and T5 Hydraulic clutch? 1965 - 1973 Classic Mustangs -General/Talk- 3
F Engine Lifter Replacement (W/ heads off) questions SN95 4.6L Mustang Tech 1
L 2000 GT Head Gasket - Leaking Coolant; mileage = 71,000ish 1996 - 2004 SN95 Mustang -General/Talk- 1
R Engine Head to manifold port mismatch especially cooling ports Fox 5.0 Mustang Tech 5
95TT347Cobra BEST SWAP OPTIONS! 05 GT 4.6 3v (Threw Rod), I have a 4.6L 2v out of an 04 GT and 4V in A mark. Suggestion? 2005 - 2009 Specific Tech 2
ClevelandTim Engine Heads and Cam Swap. Am I doing it right so far? Fox 5.0 Mustang Tech 2
84blkstang Engine What Valve covers fit the trickflow heads and rockers without modification ? Fox 5.0 Mustang Tech 4
U Engine Replacing the gasket on a gt40 head need some advice Fox 5.0 Mustang Tech 36
ClevelandTim Engine Head & Cam Swap Parts Fox 5.0 Mustang Tech 5
M Fox General/Talk Skip White Aluminum Cylinder heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
ebowie 347 wiseco pistons and trickflow 11r heads 1994 - 1995 Specific Tech 4
6 Will GT-40 heads fit a 1969 302? 1965 - 1973 Classic Mustangs -General/Talk- 7
L Engine HEAD GASKET HELP !! Fox 5.0 Mustang Tech 6
JRerecich Engine '88 GT Has No Power Above 3000 RPM After Trick Flow 11r Heads Install Fox 5.0 Mustang Tech 67
C Bringing an old 289 back to life 1965 - 1973 Classic Mustangs -General/Talk- 7
M 408 Stroker build (what heads) 1965 - 1973 Classic Mustangs -General/Talk- 5
M Porting heads diy yes or no? 1996 - 2004 SN95 Mustang -General/Talk- 1
K Engine swap help Other Auto Tech 1
C 2001 v6 head gasket 1996 - 2004 SN95 Mustang -General/Talk- 0
ebowie 351w with Trick Flow 11r heads with BBK tuned headers in 1995 SN95GT fit ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Foxbody1988 Engine Head gasket or what? Fox 5.0 Mustang Tech 8
0 02 mustang GT leaking coolant after head gasket job... 1996 - 2004 SN95 Mustang -General/Talk- 1
I Upgrading head unit in 2010 base, double din dash? 2005 - 2014 S-197 Mustang -General/Talk- 5
GT1966 Engine Lifter Removal - Windsor Jr. Iron heads Fox 5.0 Mustang Tech 11
M Skip White aluminum cylinder heads, reviews 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
jenrik Pi intake on non pi heads SN95 4.6L Mustang Tech 18
KZGUNS Promaxx heads on sale!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
C Engine 289 block / 351w heads Classic Mustang Specific Tech 3
R Engine Did I install my cylinder heads wrong Fox 5.0 Mustang Tech 3
P What heads are these? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
M For Sale 78 King Cobra Parts - Heads, Intake, Exhaust Manifolds, Radiator, AC Condenser, AC Compressor Mustang II Parts 0
B Head gasket repair 1996 - 2004 SN95 Mustang -General/Talk- 2
Scott7512 Engine Boost with explorer intake and heads Fox 5.0 Mustang Tech 3
M New project car help - engine head bolt size? 1965 - 1973 Classic Mustangs -General/Talk- 1
