Thanks. Now that I read about your setup, I think I could just forgo spending the money on the drain bottles. I could just tee off a section of line at the bottom of each jog to allow a place for water to collect with a ball valve at the bottom.It's good to have about 35-50' of pipe between your compressor and your quick disconnect. Somewhere in that 35-50' run you should have a few vertical jogs with ball valves at the bottom of each. I think I have 4 total jogs with a valve at the bottom of each. After my up/down runs it goes to a water catch can/regulator, then you should have a desiccant filter , then to your quick disconnect fitting.
