  • 1994 - 1995 Specific Tech
no blower going stroker, cost?
  • Thread starter Thread starter catpunk
  • Start date Start date Apr 21, 2007
C
catpunk
12
Michigan
Apr 21, 2007
  • Apr 21, 2007
What is the real world cost of a 331 stroker? What do I absolutely have to change? Can I get by with a Cobra intake until, I can afford a better one? What about heads, I have a ported set of 351's sitting on the shelf? I have to rebuild this winter and I might as well stroke if I can afford it. Can I just add pieces as money becomes available. My car is a 95' vert 5.0, T-5, exhaust,gears,K&N that I drive everyday during the summer.
ProKiller
3,064
15
78
PA
Apr 21, 2007
  • Apr 21, 2007
as far as h/c/i, a cobra intake will be enough. the 351 heads probably enough. granted your not utilizing all the power you could be but it will work. i would suggest 24# injectors, and at least a 190lph fuel pump. mine cost me about 5k when it was all said and done.
go-stang5.0
2,244
Glenview,Il
Apr 22, 2007
  • Apr 22, 2007
Mine about 5k also. But I have afr heads w/ upgraded springs and a 7qt pan and aluminum balancer and alum. flywheel so if you went cheaper on these items you could save a lot. Oh and I also had to get a new block as I put a hole in the old one.
juiced_94gt
1,143
Southern California
Apr 22, 2007
  • Apr 22, 2007
I've spent about 6k on my 331 build up...but thats with AFR heads with upgraded springs, trick flow track heat manifold, tfs stage 2 cam, balancer, timing cover, water pump, oil pump, new lifters, new pushrods, King cobra clutch kit, aluminum driveshaft, lightning mass air meter, 24lb injectors, gaskets, and almost all fasteners since my old engine is still on the car, it will be going in in 2 weeks, plus save like 400.00 for a tune when your done...technicaly, you could keep all stock stuff on a 331 but you would not get full potential out of it, a cobra intake will work but when you switch you WILL see gains in HP same with heads and all the other stuff.
Cwalk
78
Virginia Beach, Va
Apr 22, 2007
  • Apr 22, 2007
331 shortblock: $1,600
trickflow top end kit: $2,300
thats about 4k. should be at least 300-350HP too. maybe even more depending on the compression ration of your shortblock. that's a shortblock from M&R engines. it's probably a seasoned rolled. but roller blocks are good up to 450-500. at least a consistent 450 with no detonation.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
General engine ID for bolt on upgrades
  • 2stroke1971
  • Jun 20, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2024
nickyb
