The Navigator should be out of the shop in a few days, maybe end of the week…
I have other transportation secured until then.
Been meaning to get this written down...
T5 Trans, from a 1984 SVO Mustang w/ Hurst shifter (confirmed with the ID tag)
1 - 4.03
2 - 2.37
3 - 1.49
4 - 1.0
5 - 0.86
Rev - 3.76
8.8 Limited Slip (Eaton), with 3.27 ratio gears.
Tire diameter is almost exactly 25"
Cruising at 70mph should be around 2,650rpm. I will be looking into swapping out 5th at some point, as I literally spend 1-1.5hrs a day running 70mph...
I thought it was common. Astro performance comes to mind as being the provider for gear swaps, but seems they are no longer around.I have a question in this regard...
What gear ratios [can] you get if you tear one down and install what you like? Does anybody know if there are specific limitations?
