xYoung347x
- Nov 3, 2003
- 382
- 0
- 0
the only way the 331 pushing 420hp is the guy has a roller cam w/ some bad@ss spec/ big heads (AFR 205 heads) and hes shifting about 7500+ rpm.
Those same people wonder why their E cammed 347 won't even run 12's
Do your HW, making good power (over 400rw within streetable rpm's) with a 302 stroker is EASY, but is pricey..Grn92LX said:Theres a guy on here (ninjacoupe) making just under 400rwhp with his 347 witha small afr 185 head. Its VERY easy to make over 400hp on a 302 stroker if you know what your doing. AFR 205 heads or the FTI stroker series 185's, ported TW's, ed c cam and an rpm2 intake (or similar) and your over 400 easily. Lots of guys call BS because they have a 331 or 347 with JUNK parts that is slow, so of course no one else can make better #'sThose same people wonder why their E cammed 347 won't even run 12's
Im talking about having to have a certian amount of vacuum... And then the computer being picky...GTJake said:Like what?
Jake
moneypit94 said:Im talking about having to have a certian amount of vacuum... And then the computer being picky...
Keep in mind that with the added cubes, the cams become less "wild" so to speak as cubes "eat up" duration and such. Everytime that piston goes down and the intake valve opens, you are pulling in more air... even at idle, so this will help mask some of the idle issues and such that the same cam would yield on a 302 motor.
whats the dyno numbers? we have almost the exact same combo.twstd50 said:Here's my combo:
331 w/all forged internals
xe274hr
TFS track heat intake
off the self TW heads
Bassani o/r x
spintech prostreets
pullys
4.10s
3000 PI converter
BBK headers
1.6 rr
Aluminum Drive Shaft
24lbs squirters
190lph fuel pump
fpr
70 mm tb
75 mm pro m
all a/c deleted
C&L True Flow inlet pipe
It doesn't put up the best dyno numbers but I'm able to surprise a lot of people at the track... being that it's a heavy vert on 18'' radials.
