here we go....FINALLY:
LF fender is the issue herem so we ruled out coilspring mis-installation, bent strut, improper spindles, wrong ball joints, damaged control arms, damaged strut mounts, the works.
Ride height is DEAD ON Right front and Left Front
So why is the fender rubbing the LEFT FRONT tire and not the right?
Swapped front wheels to stock 1995 mustang for comparison. Kept my same tire size 245/40/17
same issue...LEFT FRONT tire contacting LEFT FRONT fender
All things being equal, I must assume that the left front fender is NOT within spec and/or has been warped or damaged (although it looks fine visually).
Even with MAX NEGATIVE CAMBER, I didnt have enough to clear the Fender on the LF position. I went as far as test fitting a 1995 lower control arm with different tie rod ends for MAJOR negative camber....it was way too much and pushed the front tire OUT ALOT.
Mechanically, EVERYTHING on the front suspension is PERFECT.
I've had this thing apart and back together at least 5 times this week.WHEW
Im ordering coil overs so that I can adjust my ride height as I see fit. They will arrive next week, I'll post when they arrive
